Converting 2010 per headlight housing to 2013 HID PROJECTOR
djmacc
Hi just bought my Raptor couple weeks ago and I ran across a couple of 2013 OEM projector light housings in rough shape. The housings have a couple damaged clips and the lenses are scratched. I plan on taking these housings apart and removing the lenses to add halos so I'm hoping to swap the lenses from my 2010 lights which I assume will work fine but my real question is can I transplant the projector/HID guts of the damaged 2013 housings into the 2010 housing? I guess a simpler way to ask this question is can I transplant the projector interior guts from the 2013 OEM lights into my 2010?
Dan
IRONMAN
Well-Known Member
MICHIGAN
Nope, totally different backs. One is set up to receive the ballasts and are deeper because of the projectors.
djmacc
djmacc
Thanks I pulled the 2010's out and there are a lot of differences. I am going to remove the lense from a 2013 next week and compare the fit.
djmacc
djmacc
What about the clear glasses, are they the same?
Finally got back to the lights and found that the halogen lens fit the projector housing with the exception of a couple of the lens hold retaining clips don't line up. I am not to worried about that as I clamped the the housing and lense together and let sealant cure. Once it cures that lense won't be going anywhere.
TuFerLife
Good info... I'm going to have to use the lenses from my halogens on my OEM projectors because I bought them like you did with some moisture on the inside of the lens. Tried to clean them but it was a big PITA, so I'm just going to bake all the headlights and take them apart....
How's the process going so far?
Aaron313
El Paso, TX
I would like to see what you guys come out of this with. On the fence of buying some HID's here in town but they have some deep scratches on the the right headlight and would be up to using my halogen lenses as well
Sent from my iPhone 6s using Tapatalk
djmacc
djmacc
Everything came out great. I installed 2 concept strips, a halo and a demon eye in each housing. I installed the color morph led'so I can get the lights to match the same amber color of the grill or any other color for that matter. The worst part of the process is getting the lenses off. It's tedious even after baking them. A heat gun makes things move along better.
djmacc
djmacc
Headlight project
Here are a few pics of my project.
