Bunch'o'Lights
OUTCAST
Watson, Louisiana
For my 13' Scab (That has yet to arrive), I've accumulated a closet full of pieces and parts, AKA: Mods. Among these pieces and parts, I chose to go with a Ford Racing Light Bar and the 4 KC Hiliters, 2 long, 2 Fogs. I like the original, "back in the day" look of the first Raptors and the light bar, but, I am also a fan of the new stuff, thus I have a set of Rigid Dualies sitting in the same pile of boxes.
Here's my question...should I wire the KC and Rigid fogs on same switch and all longs on another or separate them all and that way I can flip switches for the "Close Encounters" replay?
I don't think the LEDs draw a whole lot of amps and would be fine on a switch with the KC's. I could be wrong. I just figure they'll all be on together anyway.
pat'sRAPTOR
Everywhere
Depends on how many amps those 4 kc lights draw. You might have to put the 4 kc lights on one and the two dually's on another
OUTCAST
OUTCAST
Watson, Louisiana
I guess that's really what I'm asking.
The Hiliters have a 20 amp fuse in the wiring harness and the Dualies a 15 amp. So that would be 35 total, but fuse rating are usually a bit higher than what is needed. I've seen guys here on the forum replace and swap fuses and relays around to accommodate lighting and other electrical mods. I'm pretty sure I'd be fine, just wondering if there would be a need to not have all "on". Maybe at night, trailing another vehicle is all I can think of.
G & P Racing
I agree, four HID's across the front has a certain cool factor. For me, having fogs, spots, driving lights all on there own switches let me choose what works best for a given situation. All on can be too much sometimes. Kick out some pics of your new setup when you can.
G & P Racing
All circuits have the same gauge wire. 3 and 4 fuses and relays can be replaced w/ 30amp. Not even sure what a 10amp on 4 would be useful for.
You can use it for anything. Just tie it to a relay and you can switch a larger load.
OUTCAST
OUTCAST
Watson, Louisiana
I use my number 4 switch for my for my rear facing amber LEDs on my bed rail mounts.
See, now I know! Lol
---------- Post added at 11:44 AM ---------- Previous post was at 11:42 AM ----------
I knew that, I just didn't think along those lines. Too many Top Shelves last night! Lol
