I think we have one of the best kits available right now, which is why we sell it.
Our CrystaLux XHP Series utilize CREE XHP50/XHP70 chips to give a terrific output. And the bulb is designed not to cause glare to oncoming drivers. Our XHP Series are offered in all of the popular bulb sizes including H13 for the 2014 and older F150s.
We recommend our XHP Series for non-projector housings (OUR XHP50 are for non-projectors but we do have our XHP70 which are for projectors, it's a single diode instead of 2 diodes, but it's not for ALL PROJECTORS, you want projectors that are open on the back for the fan/larger bulb).
We also have our new G9 Series, which are actually better then the XHP. They throw more lux BUT they are not offered in H13. They are mainly for single beam applications but are for all housings including projectors. Our G9 are so far the best LED lights we've tested on the market (and we've tested all the well known products. OPT7 FluxBeam, Profile Peak Performance, Diode Dynamic SL1s and a few other popular brands on amazon). So far, only DD SL1s came close to our G9 Series, everybody else was behind in terms of lux and design.
We only sell those 2 styles of LED Conversion Kits under our own name because we wanted the best of the best.
Our XHP Series are the same as the Putcos, they just use a different cooling method.
I would not recommend the OPT7... you don't get a lot for your money and they feel really really cheap. We did a shootout a while back and have a new shootout coming up (the new shootout has about 5-7 different brands of LED bulbs, the most popular we found on amazon and from recomendations so we can show real results).
Photos attached of our XHP Series H13 bulb and the G9 Series for reference (the G9 are not available as I said, we did a test run but the collars didn't seat right so we're still tweeking the collars on the G9 Series)
We're also a vendor here so you know you can rely on us:
F150 Specific Kits:
Vehicle Specific - Ford - F-150 (2009-2014) - Page 1 - 4x4TruckLEDs.com
Use coupon code RAPTORFORUM and you also get 10% off
