Baja Designs 40" Wiring Help
srs
Tomball, TX
Does anyone know how the temp switch is wired for the use of the strobe function on the Arc bar? Is it temp to ground or temp to power source?? I see on the stock wiring harness the temp switch there is a red and black wire going to it, but it goes right back into the harness. I don't have the original harness, just adding a temp switch to the third wire coming out of the bar but I'm not sure how it's wired. Thanks!
srs
srs
Tomball, TX
Yeah, I sent them a message both on here and through their website. I have posted on the vendor forum for them in the past, but they never responded to that.
Jimbo
Mad Frog Mattis
IL
Bailey will be here shortly. Those left coasters always start their day late.
RLTW
TX
Someone's adding the seizure affect
Baja Designs
Sorry for the delay in response! I was out of the office Friday and now I'm catching up. For the OnX6 the green wire controls the mode (High, Low, Strobe)
This can be activated by running the green wire from the light to a momentary switch. From the momentary switch all you need to do is run a wire to a ground. When you hit the momentary switch once it will go from high to low. If you hold it for 3-5 seconds the light will strobe.
*Note: Hi-Power OnX6 doesn't strobe. Only standard and Racer Edition.
Hope this helps!
-Bailey, Baja Designs
srs
srs
Tomball, TX
Hope this helps!
Thanks Bailey. I got it set up.
