Otis857
So I put 2 LED light bars on Aux switch 1 and some M&R hood pod lights on Aux 2. My question is; has anyone wired individual or multiple Aux switches to the Hi beams? Seems like a good way to turn your LED's on and off quickly with the dimmer switch. And you're likely to have your hi beams on when you are running off road lights, so it makes sense to me. Should be doable since the aux switches use their own relays, and the hi beams would be not much more than a signal wire. I would still want to keep Aux 3&4 as is since 3 isn't currently used and 4 goes to some back up lights.
If so, wiring diagrams, locations, etc.?
TIA
TIA
