actual fog lights, and a stock headlight switch
EdgeR6
Alpine, Ca
I want to get fog lights, that I can use in bad weather on the road. Even with hids the lighting in the city and wet roads make it difficulate to see. Has anyone been able to buy a stock headlight switch with the foglight option and use that to wire up a set of fog lights.
Rookie
Fort Wayne, IN
Ya I would just get a set of flush mounts and wire them to a stock switch. Not much different to flip that than it is to pull the headlight switch out.
Wrong Way
Someone on here has done this already. He switched out the Raptor light switch to a regular F150 switch that has the "pull" fog light feature. I dont remember who did it but im sure if you search enough you will find it. Good luck.
E
EdgeR6
Alpine, Ca
