Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Lighting Modifications Forum [GEN 1]
Actual FOG lights (or bracket)
This is a discussion on Actual FOG lights (or bracket) within the Ford Raptor Lighting Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Does anyone make a pair of ACTUAL fog lights for the Raptor bumper? Everything I see is LED Pods clustered ...
Like Tree1Likes
  • 1 Post By phydough
Sponsored By: KC HiLiTES
Old 05-13-2014, 03:16 PM   #1 (permalink)
Junior Member
Default Actual FOG lights (or bracket)
Does anyone make a pair of ACTUAL fog lights for the Raptor bumper? Everything I see is LED Pods clustered with driving lights or things like "wide driving" which I believe throw light out too far to leave on with low beams. I'd like something that puts out a "traditional fog" wide beam that works with LOW beams and cuts under fog.
If no one makes a light kit, how about a bracket that can mount a "traditional" pair of fog lights (Like Hella 550s) in the correct position? Forward enough for the light to clear the bumper, but still somewhat protected from impact.
Bonzo is offline   Reply With Quote
Old 05-13-2014, 03:27 PM   #2 (permalink)
Chris@FreedomMotorsports's Avatar
FRF Gofur
Actually, the Rigid Dually flood light in amber, while being an LED light, the output is not as high as others and is great for using as fog lights to cut through the fog. Not being white with a cover and not having a light output that is too intense, they are a great option when paired with the Rigid foglight mount kit. Although the mount kit if designed to hold two pair of their Dually lights, it is possible to either only mount one pair or mount two pair of amber lights, OR if you wanted to, mount one pair of amber and one pair of something else and wire the two sets independently of each other so that you can run one or the other. Below is a link to the lights I am talking about, let me know if you would like to know more about our special pricing on them during our anniversary sale.
Rigid Industries LED Lighting | Leader in Off road LED light bars, truck LED lights, Marine LEDs, and Industrial LEDs
Chris@FreedomMotorsports is offline   Reply With Quote
Old 05-13-2014, 03:38 PM   #3 (permalink)
Junior Member
Thanks for the quick reply. Doesn't the flood light also project vertically as well? A traditional fog light is a very flat beam with little vertical dispersion.
Old 05-13-2014, 03:40 PM   #4 (permalink)
FRF Gofur
It does, but it is more wide horizontally than it is vertically.
Old 05-15-2014, 12:09 AM   #5 (permalink)
justcozz's Avatar
You could probably do some creative aiming with Chris' suggestion to make it work. I haven't had a desire to run just the fogs because it's not that big of a deal here.
justcozz is offline   Reply With Quote
Old 05-17-2014, 05:04 AM   #6 (permalink)
phydough's Avatar
Bonzo, because you want ACTUAL fog lamps, don't even bother looking at any of the led lamps that are common here. Stick with Hella, PIAA or something that is a REAL engineered true fog lamp. The beams are designed properly as fog lamps, not flood lights with amber covers.
There are only a couple led lamps, look at Headlights - Products - J.W. Speaker Corporation, PIAA | LP 530 High Intensity LED Fog Light Kit #05370 and My Hella Lights :: Optilux® 4" LED Fog Lamp Kit. A big plus in favor of the JW Speaker lamps is that most are DOT approved. THe Optilux are SAE/ECE approved as well.
For brackets, try some of the forum vendors that offer brackets that mount multiple led cubes in the outer bumper holes. You may have to drill a new hole and/or shim to get the light where you want it though. Like these, http://www.off-roadperformanceandacc...r-rig40235.htm, probably others have them as well.
You could fabricate mounts to put them in the center bumper hole too. The drawback here is, the lights are toward the center of the truck, not ideal placement for fog lamps.
I have Hella 4000 fog beams mounted under a KC light bar.
phydough is offline   Reply With Quote
Tags
bracket, fog lights, low beam
Actual build time mudblood 2014 Ford SVT Raptor Forum (Reply Only) 7 11-18-2013 09:52 AM
actual fog lights, and a stock headlight switch EdgeR6 Ford Raptor Lighting Modifications Forum [GEN 1] 8 03-15-2013 09:11 PM
Actual wait times TTOKC Prospective Raptor Owners 12 08-17-2012 10:20 PM
Actual Delivery Date? Mavrik 2012 Ford SVT Raptor Forum (Reply Only) 10 11-24-2011 12:25 AM
Actual wait time.. Rapford75 2012 Ford SVT Raptor Forum (Reply Only) 6 11-23-2011 07:58 AM
