BOBONTUESDAY
- Joined
- Nov 15, 2014
- Posts
- 75
- Reaction score
- 42
@BOBONTUESDAY, is that 3 40" behind the grille? Can you take a picture of the mounts? I just got a 40" and want to see how you mounted it.
We used the rigid brackets for the top one with some metal extensions, on the bottom I made the brackets out of some metal, for the top one I cut a slot on the back to pass the tranny cooler hose, also we relocated the horns, I'll get you some pics soon. We only got 2 in, 3 looked like to much and would of created some cooling problems, shit would of been like a wall of bars if we 3, 2 was enough. We also used factory bolts, the same ones you use on the bottom 40's, pictures will explain it better.
