3rd Brake Light Pin out
ASars
Does any one happen to know the pin out on the connector for the 3 LEDs on the 3rd brake light I know there should be ground, Brake, Running light can any one tell me which one is which on the lamp it's self. I have a lamp but no harness and thinking about hard wiering it since apparently ford and all the parts supplies won't sell the harness with out buying the entire lamp.
Unfortunately colors wont help as I have no harness and will be creating my own.
t_j
Chicago, IL
Break out your multimeter in resistance test mode, the center should be ground, go from ground to each of the other 2 pins, the pin with the higher resistance is the DRL lower resistance is brake.
A
ASars
Ok thanks for the info didn't think about the resistance factor figuring out which was ground was my biggerst concern
Fyrman702
Henderson, NV
I have been working on a third brake light project. Im testing it right now. Removed the circuit board and trying some other types of leds. I will post my results when finished. I did figure out the wiring on my 2013.
The white pin is ground (-)
The red pin is brake (+)
The blk with white stripe is running (+)
The solid blk is cargo (+)
A
ASars
Awsome thanks for the info that exactly what I needed have a split standard F-150 harness coming in today (ford lost it as the SVT Raptor harness but as with the last 2 I ordered when it arrives it's always the 3 bulb one not 2 bulb one connector Raptor one so in going to cut the 3rd build connector off and solder it right to the pins on the lamp I'll post up some pics and pin out when I test it all out.
t_j
Chicago, IL
You should test this, the wire colours often change between model years, @fryman702 maybe you can post the pin positions for those as those change less often.
A
ASars
Well got out the multimeter during my lunch break and now I'm stumped I get a measurement of resistance between the center pin and the right pin but nothing from the left pin I've tried every possible combination but absolutely no reeding thru the left pin I even tried a second multimeter to be sure my meter wasn't messed up.may just hook up some power and test it that way
A
ASars
Ok I figured out the pins with the light mounted on the truck passenger side is ground, middle is brake light, and driver side is running lights. Just installed working great
Raptor601
Mississippi
Did you make any progress on this? I too am thinking about handwiring my circuit board in my OEM 3rd brake light. I really wanna keep this on my truck and can't stomach paying 300+ for a new one.
BAD454SS
Banned
HELL Arizona 6.2L There is more to life
luckily a year ago i was watching a few at $100 or so bucks on ebay, then i saw the price jump. I went to amazon right away and found one for $105 ,and bought it right away . Just put it on a few weeks ago my orginal had turned yellow . After 7 years.
