2014 dome light help
nwporter
Does anyone know the wire color or have the wiring diagram from the 2014s trying to wire up under the kick plate for the dome light? I am trying to install the door sills from recon but cannot seem to locate the right wire. I found the 2013 one and that is not the correct wire. Ford was no help either. Any help would be appreciated.
Thanks
aka grumpy car stereo guy
2013 and 2014 are the same. the dome supervision wire is positive trigger. grey/purple at the bcm. grey 12 pin plug. also a purple wire positive trigger (puddle lamp) grey 26 pin plug. pin 1.
I am trying to install the same lights on my 2013, you say you have the diagram? I am pulling my hair out on this one, any help is greatly appreciated.
cyberaptor
I know the wire colors, what I do not know is where in the cab I can intersect these wires (gain access to)
