2013 stock LEDs headlights on my 2011
98infinity
Hey as the title says I have 2013 led headlights on my 2011. The drives side is flickering on bumps and now is out. How would I looks into it if it's blown or just lose or something. Have to pull the battery out? What fuse for it? Does the fuse run both lights or just one? Thanks!
bmacked
IL
Check your grounds and morimoto box connections. I had a similar issue with the retrofits on my old truck and it ended up being a bad control unit.
smurfskier
Binghamton, NY
I had. similar issue s well. thought it was the morimoto control box but actually had some corrosion on the plug that goes into the morimoto box. replaced harness (used dialectic grease on all connectors this time) and have had no problems since.
2014RubyRed
Galesburg, IL
Dielectric grease is definitely your friend when it comes to ANY electrical connections. Especially on all of the headlight connections/connectors.
