Now I am being told Rigid changed the wiring harness and these lights may or may not work with present harness. May have to rewire everything. Duoooo!
Thats right I would probably swap your 30Amp fuse for a 15 you can get at most autoparts stores. Don't pull your 15 and 30 and switch those back and forth because you have lighter gauge wires for switch 3 and 4.
When I had Rigid on the phone, I asked them about swapping fuses for lower recommended amp ones. They said it was a good idea but that the lights were internally protected as well.
---------- Post added at 03:40 PM ---------- Previous post was at 03:36 PM ----------
Rigid changed plugs a while back and I have pictures on the forum of the two different styles.
They will also send you an adaptor plug free of charge if you have the old style plug, if you want to do it that way.
Found the picture.
Yes the new style is the grey square one, so you should be fine.
