Wheel bearing replacement
YAMAHATOO
Rotated tires today and there is a little play in passenger in front side this means wheel bearing replacement or whole hub assembly also? rock has the whole assembly for 180 and change I think its the whole assembly cuz ours aren't serviceable ? yes , no?? thanks
The Mav
I guess it depends who's doing the work.
I'm guessing thats a quote from a ford dealership?
Sounds about right along the lines of what they would take.
Deleted member 12951
Not sure how your warranty is or not but I had both mine replaced under the 5yr/60k warranty
Y
YAMAHATOO
what is the cable on the new wheel bearing? iam guessing it is for a sensor but in the thread of how to it dosent mention it
Yukon Joe
Russellville, AR
ok thanks it just dosentbmention the sensor in the how to article, what are torque specs? where is loc tight used? hate to be so stupid but iam not all that mechanical , I apptreciate the help
There is a sticky thread that has all the torque values that was created by @pirate air
Not sure on the loctite.
@Yukon Joe :baby: :baby:
Drive your raptor here!!!!
www.runraptorrun.com
( * Y * )
