Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
What seems to be the problem Raptor??
This is a discussion on What seems to be the problem Raptor?? within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
So I took my raptor out to the beach this past weekend to try the new M/T tires and had ...
Old 07-25-2011, 06:31 PM   #1 (permalink)
LEGORAPTOR's Avatar
Question What seems to be the problem Raptor??
So I took my raptor out to the beach this past weekend to try the new M/T tires and had a badass time trying this baby out in the sand dunes. After though when I was on my way back home, Everytime I got to about 80mph I felt the truck shake/vibrate a lot. The I also let the stering wheel go and it would slowly but surely start leaning to the right side. Is it the alignment? Do I have to get tires balanced again? Was is during the crazyness of my off roading that this occured?
P.S- I'll post pics and vidz later this week of my adventure =P
THX
LEGORAPTOR is offline   Reply With Quote
Old 07-25-2011, 06:42 PM   #2 (permalink)
pirate air's Avatar
will plunder your booty
If it shakes its a tire balance problem. I would first check that you don't have mud/sand packed up inside the wheel. If you do, than that could very possibly be your shake. If not, it sounds like the tires need re balanced. The pull could be an alignment issue, low tire psi, or bad tire.
pirate air is offline   Reply With Quote
Old 07-25-2011, 06:54 PM   #3 (permalink)
LEGORAPTOR's Avatar
Smile Thanks
I'll check tire balance and alignment this week as well as do another pressure wash on wheels and undercarriage just to make sure theres no sand/mud stuck under there. Thanks a lot.
Old 07-25-2011, 09:16 PM   #4 (permalink)
Rat
Senior Member
If you were having "fun" you may have bent something ? How is the bed alignment ?
Rat is offline   Reply With Quote
Old 07-25-2011, 11:49 PM   #5 (permalink)
Badrap's Avatar
Everyone says these things won't do a 100+, BS mine will push 120 but it feels like she is wanting sand and not pavement. It has done this since day one. In the desert she feels fine with no sideways shake or control problems.
Badrap is offline   Reply With Quote
Old 07-26-2011, 10:11 AM   #6 (permalink)
DEADEYE's Avatar
DId you put new rims on with the M/T's ? Check the weights , tape weights ? It ahould be almost impossable with out noticeing when you did it ,but you could have knocked a weight off . I would take it back to where you bought the wheels or had them mounted.
DEADEYE is offline   Reply With Quote
Old 07-26-2011, 10:18 AM   #7 (permalink)
whtrapta's Avatar
Ostrich Wrangler
Sounds like tire weights. 100+? I put mine on the dyno and as soon as I hit 100 power was cut. The fastest I hit was 102
Just when you think your done modifying... your not.
whtrapta is offline   Reply With Quote
Tags
alignment, balance, beach, off road, tires
Heated seat problem BIRDMAN Ford Raptor Problems and Questions Forum 96 12-07-2016 06:54 PM
Bad Problem - Great Resolution Lucky14 Ford Raptor Maintenance Forum 12 06-24-2011 09:08 AM
another Sync/Nav problem today (2nd time) HoustonRider Ford Raptor Problems and Questions Forum 23 05-27-2011 05:06 PM
Bakflip F1 install problem? OneArmedViolinist Ford Raptor Exterior Modifications Forum [GEN 1] 11 04-27-2011 01:38 AM
Driver window problem BIRDMAN Ford Raptor Problems and Questions Forum 8 04-15-2011 07:25 PM
