Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Transfer case Oil
This is a discussion on Transfer case Oil within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
What oil do I use for the transfer case. I understand that the transmission uses ATF LV, running a 2010 ...
Like Tree1Likes
Old 10-08-2016, 09:55 PM   #1 (permalink)
Junior Member
Default Transfer case Oil
running a 2010 raptor 6 Speed Auto
medic701 is offline   Reply With Quote
Old 10-09-2016, 01:01 AM   #2 (permalink)
Ruger's Avatar
Ford specifies its proprietary transfer case lubricant and has never published its specifications. Given that, the safe bet is to go to the Ford parts counter and buy a quart. That's what I did.
"Free men do not ask permission to bear arms." - Thomas Jefferson
"I like my coffee black, and my tea in the harbor." - Jay Posey, author
Ruger is offline   Reply With Quote
Old 10-09-2016, 01:27 PM   #3 (permalink)
Chris@FreedomMotorsports's Avatar
FRF Gofur
This^^^ in part. SOME of the transfer cases require Ford Specific T-case fluid and SOME require Mercon V. According to my Ford sources, n easy way to tell which one yours requires is to look for the Ford oval logo stamped into the side of the T-case. If it does have that then it requires the Ford specific fluid, if not it requires Mercon V transmission fluid. Now, whether I was told correctly on that part of identifying that, I honestly don't know. But I do know that my 2011 Raptor T-cse required Mercon V while my 2014 Raptor requires the Ford specific fluid. The best thing to do is go to a Ford dealer parts department and have them run your VIN number to narrow down which one your specific truck requires.
Chris@FreedomMotorsports is offline   Reply With Quote
Old 10-09-2016, 02:33 PM   #4 (permalink)
Junior Member
Ok ill check it out and call them.
Old 07-23-2017, 01:29 AM   #5 (permalink)
Humvee21's Avatar
Was about to do a transfer case drain & fill before I found this thread. I already bought Valvoline compatible transfer case fluid. It is fully synthetic and specifically states it is XL-12 compatible. Would you guys still recommend against using it? Should I still go with the Motorcraft?
Link to Valvoline fluid https://www.valvoline.com/our-produc...fer-case-fluid
Humvee21 is offline   Reply With Quote
Old 07-23-2017, 10:47 AM   #6 (permalink)
Ruger's Avatar
I have a 2011 and my owner's manual said to use Ford Transfer Case Fluid, so that's what I used. I have never had reason to distrust a vehicle's owner's manual until just now. Chris, are you dead certain about this?
Old 07-24-2017, 09:27 AM   #7 (permalink)
FRF Gofur
I am indeed certain about this. I found out about this when I needed to service my 2011 and was in for TSB service of the drive shaft pinion yoke a few years ago and this was explained to me by the Ford Master tech doing the service on my Raptor.
Old 07-24-2017, 10:02 AM   #8 (permalink)
Ruger's Avatar
Thank you, @[email protected]!
Old 07-24-2017, 10:04 AM   #9 (permalink)
FRF Gofur
My pleasure Sir!
Old 07-24-2017, 12:33 PM   #10 (permalink)
ogdobber's Avatar
I kinda think its just a case of developing a better job specific oil over the years. There is nothing special in the tc (like clutch plates etc) Mercon v works...but the t-case oil lasts longer
2012 SVT SCREW
ogdobber is offline   Reply With Quote
transfer case ?!?! 2011_Ford_Raptor Ford Raptor Problems and Questions Forum 6 08-16-2016 08:25 AM
Blown transfer case??? johndjmix Ford Raptor Problems and Questions Forum 19 10-22-2015 04:51 AM
SVT Transfer case vs Crew cab Acerni Ford SVT Raptor General Discussions [GEN 1] 0 03-30-2015 06:03 AM
Transfer case maybe? Little man Ford Raptor Problems and Questions Forum 14 03-04-2015 12:18 PM
Transfer case being replaced... Steele16 Ford Raptor Problems and Questions Forum 12 11-14-2014 02:17 PM
