Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Tire problem after rotation
This is a discussion on Tire problem after rotation within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
Long time lurker here. I had my tires rotated for the first time and there was no abnormal wear before ...
Old 08-02-2014, 08:53 PM   #1 (permalink)
Junior Member
Default Tire problem after rotation
I had my tires rotated for the first time and there was no abnormal wear before I did so. After a week or some I now have inner tire scalloping going on. Someone told me they were out of balance. Can I just rebalance, check alignment and get some more life out of the tires?
Thanks
OrangeTiger is offline   Reply With Quote
Old 08-02-2014, 08:57 PM   #2 (permalink)
RDFTS's Avatar
aka Rick
I would post pictures
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15' | AR Run 15' | TRR Baja 16' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 08-02-2014, 09:10 PM   #3 (permalink)
Junior Member
Okay, when I get home and to a computer I'll upload some.
Old 08-02-2014, 09:51 PM   #4 (permalink)
Junior Member
Old 08-02-2014, 11:06 PM   #5 (permalink)
dataustin's Avatar
Tiger, same here... The first time I had this problem, Greg introduced me to 'road force balancing' which solved the problem. Most will say that the result is only as good as the technician. Well, the last time I had them balanced, the tech couldn't get one of the tires over 90.
Just the other day when I had them rotated, there was a 'knocking' sound. Turns out the kid put three weights on the rim, which didn't rub on the front brake but did rub on the back.
Bottom line, I'm right where you are today and trying decide where to take the truck next...
dataustin is offline   Reply With Quote
Old 08-02-2014, 11:19 PM   #6 (permalink)
RDFTS's Avatar
aka Rick
What air pressure are the tires set at?
Old 08-04-2014, 08:46 PM   #7 (permalink)
Junior Member
Just checked them all, about 43-44 psi on all 4. OEM at KO's
Old 08-05-2014, 09:47 PM   #8 (permalink)
Secret Squirrel's Avatar
Check your alignment, specifically the toe adjustment. I had the same problem after the first tire rotation. The front tires started to get the same inner scalloping as before. I took it to the Ford Quicklane and they found the front tires were toe out past the acceptable specs. I just had it aligned recently, so I can't see any obvious results yet. Hope this helps.
2013 SuperCrew Ingot Silver Metallic * Blue Accent Interior * Bead Lock Capable Forged Aluminum Wheels
D-Bug Screen * BakFlip F1 * Ford F-150 Bed Mat * FIM MyTouch LockPick2 * Vizualogic A-1260CL Monitor/DVD Headrests
Secret Squirrel is offline   Reply With Quote
Old 08-06-2014, 01:54 AM   #9 (permalink)
SonnyAK's Avatar
How often are you all rotating your tires? I'm doing mine every 5k, since there seems to be some issues with going too long and getting wear in them from being at one point very long. So far they're doing good, but I'd be curious if the guys with issues are going pretty long between rotations or not??
2013 Screw (Silver w/Graphics), Built 9/11, Delivered 9/17, Picked up 9/23
SonnyAK is offline   Reply With Quote
Old 08-06-2014, 03:39 AM   #10 (permalink)
debate's Avatar
How many miles are on that set of tires?
debate is offline   Reply With Quote
TPMS and tire rotation questions OrangeAddict Ford Raptor Wheels & Tires Forum [GEN 1] 14 11-26-2014 12:26 PM
Tire rotation mfrunlimited Ford Raptor Maintenance Forum 18 10-29-2013 12:07 PM
2011 Crew Tire - Tire measuerments for trailer carry superduty 2011 Ford SVT Raptor Forum (Reply Only) 11 09-23-2011 09:05 AM
Time for regular maintenance? Oil change/Tire rotation/Multi-point Inspect... Ask for "The Works" BigJ Ford Raptor Maintenance Forum 9 07-26-2010 03:57 AM
What's Ford Charging You for a LOF and Tire Rotation? BigJ Ford Raptor Maintenance Forum 18 04-14-2010 06:57 PM
