Spark plugs
litsnsirn
Do the spark plugs in the 6.2 have the breaking off problem that some of the earlier engines had? Are they of that same design?
Tom
VA
Yes, they are. And don't forget to put some anti-sieze on them before reinstalling....
jdowens1
Ford Senior Master Technician
Montana
The 6.2 spark plugs are different the the 5.4 3v plugs had. The design change was mid 08 when they made the whole plug end threaded. There was another thread on them being difficult to remove.
L
litsnsirn
Is the hole threaded all the way down, or is it like on the old engine where the open ends get crudded up?
jdowens1
Montana
I'm going to assume they are fully threaded. They are still newer so I haven't had one apart yet. I know the ego boost is fully threaded and I'm sure they are similar.
Sent from my iPad 4 using Tapatalk
fordfan
Kane PA
The head is threaded all the way, I have one appart right now for a supercharger and they are not the same style as the ones that broke off like in the 5.4 3V engines. I still suggest using a high temp nickel anti seize when installing new plugs
IRONMAN
Well-Known Member
MICHIGAN
What is the best plug on the market?
I have the 5.4 with almost 50000 miles and I'd like to change mine.
---------- Post added at 09:07 AM ---------- Previous post was at 08:45 AM ----------
Any thoughts on the Denso Iridium Power Spark Plugs.
Rakimb17
SoCal
You can never go wrong with the stock plugs.
What is the stock plug? Copper, iridium?
I had a buddy back in the Air Force that shot a plug through his Lightning. That was a very bad day. He spent about 6 grand on a new head. Truck had just come off of warranty.
NickPic83
Rockland County NY
Denso is supposed to be very good. I have always been happy with NGK. Bosch also has some good stuff too
Sent from my DROID RAZR using Tapatalk 2
