aalonso
- Joined
- Oct 25, 2011
- Posts
- 200
- Reaction score
- 190
Folks,
I currently have a 2011 Raptor with 78,900 miles. The raptor had the Roush Phase 2 supercharger installed by Roush Performance when the truck had 61,500 miles back in April 2014.
My question is at what interval and what type of sparkplugs should I use in my Raptor?
The reason that I ask is as follows; last week I called JDM Engineering to inquire about a spark plug change. I was told that I should not be running the stock spark plugs with the supercharger and I needed to change them right away with a spark plug that is one step colder and with a suggested interval change of 30,000 miles. Not being sure whether Roush replaced them or not, I contacted Roush via email and I was told the following:.......The ROUSH 6.2L supercharger kit that you have on your Raptor uses the factory Ford spark plugs; we do not change them out when performing an install. With that being said, I would recommend using the factory Ford spark plugs since that is what our kit is calibrated for. As far as maintenance goes, I would call your Ford dealer and see what they recommend; the fact that you have a supercharger on your truck should make no difference.....
Folks, if you have a Roush Raptor, please let me know which route you took in regards with the spark plug replacement
Thanks so much.
Thanks so much.
