bosssho
I have a 14' SCREW and my buddy has a 13' Screw, and I noticed just about 3 months ago, upon take off, a little bit of a “noise” that almost sounds likes a suspension squeak or movement that was definitely NOT there since Thanksgiving of 2013 when I first got the truck...
My buddy's truck is worse...same exact noise, but it does it when you brake too...so I would assume suspension parts rubbing...
it's NOT a clunk, and it's NOT viscous or anything, but just an annoyance more than anything.
I had a local shop lube a bunch of things, but no difference, and this was after a Vendor had said: I had that with my 2011. I took it to the dealership and they greased the front pinion yoke on the drive shaft. But the sound ((Kind of like a "womp womp" sound) was back within a couple of weeks. I ordered some Amsoil grease and lubed the crap out of it and haven't heard it again since and that was about 8-10 months ago. Check out the grease below and get that pinion yoke greased and see if that helps.
AMSOIL Synthetic Polymeric Off-Road Grease, NLGI #2
Any thoughts?
Any thoughts?
