Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Modifying transmission dip stick
This is a discussion on Modifying transmission dip stick within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
Installed the RPG trans cooler today. It's a nice unit. Just like stock only larger. I decided to change out ...
Like Tree12Likes
Old 07-17-2017, 04:03 AM   #1 (permalink)
R1jamn's Avatar
Default Modifying transmission dip stick
I decided to change out some of the trans fluid while I was at it (4 qts).
I new going into this that checking trans fluid level afterwards would be a challenge, as others have found out first hand.
So after adding fresh Mercon LV ATF I brought the trans fluid up to temp and then parked it and jumped out to check the fluid level.
Let me tell you......It's was really special how FoMoCo placed the dipstick right next to the catalytic converter.
I love the smell of BURNING FLESH in the afternoon!! Thank you Ford!!!
So I improvised on what FoMoCo would not. An easier way to check trans fluid level.
I drilled and tapped the head of the dipstick (6-40 UNF).
Attached a piece of aluminum flat stock (1/16" x 1/2" x 13" long) as a handle to avoid getting burned again.
Worked Great!!
2014 Supercab Ordered 9-4-13 l Built 11-12-13 l Delivered 12-6-2013 l Oxford White l Blue Accent Pkg l 801a l Tailgate step l
R1jamn is offline   Reply With Quote
Old 07-17-2017, 10:02 AM   #2 (permalink)
Ruger's Avatar
Picture of your creation installed in the transmission on the vehicle?
"Free men do not ask permission to bear arms." - Thomas Jefferson
"I like my coffee black, and my tea in the harbor." - Jay Posey, author
Ruger is offline   Reply With Quote
Old 07-17-2017, 10:41 AM   #3 (permalink)
ogdobber's Avatar
I think he leaves it out and just runs the cap?
I just use a pair of leather gloves
Ruger likes this.
2012 SVT SCREW
ogdobber is offline   Reply With Quote
Old 07-17-2017, 10:45 AM   #4 (permalink)
Ruger's Avatar
If so, then he's still going to burn his knuckles when he unscrews the cap. I hope he isn't driving around with that long handle dangling down.
ogdobber likes this.
Old 07-17-2017, 10:47 AM   #5 (permalink)
ogdobber's Avatar
lol
2012 SVT SCREW
Old 07-17-2017, 10:49 AM   #6 (permalink)
Ruger's Avatar
@ogdobber, you've done a transmission service on your truck and understand the problems associated with this. Yes?
Old 07-17-2017, 10:54 AM   #7 (permalink)
ogdobber's Avatar
Yes all too well. I like the idea of the op's dip stick and likely by the length im assuming he has a lift.
Leather gloves. Done
2012 SVT SCREW
Old 07-17-2017, 11:01 AM   #8 (permalink)
Ruger's Avatar
Leather gloves. Done.
I did it bare-handed the first time. That was three years ago, and the scars on my knuckles are still apparent.
There is an aftermarket dipstick available, but they stupidly designed it to be mounted to the firewall instead of the engine. Continual flexing makes it prone to leak.
The only solution appears to be the simple one: leather gloves. Fingerless leather gloves to aid in the manipulation of the "dipstick" in such close confines.
I imagine that there are hundreds of unhappy Ford maintenance techs all across the country...
Jimster58 and ogdobber like this.
Old 07-17-2017, 01:15 PM   #9 (permalink)
Jimster58's Avatar
Ruger - I was going to install the PA dipstick on my 2013, never got to it - glad I didn't because I like the B&M design much more. I am going to proceed with this project, as-is, but want to investigate fabrication of a mounting bracket so it is integral with the engine to prevent the potential issue which you note. If I come up with a good solution, I'll post it.
Ruger likes this.
Lions, who act, care nothing for the opinions of sheep, who idly and timidly stand by doing nothing...
Jimster58 is offline   Reply With Quote
Old 07-17-2017, 02:32 PM   #10 (permalink)
R1jamn's Avatar
Yes, I leave the dipstick out and then re-install the filler cap when done. I leave the dipstick with the handle attached in my tool box now.
Yes, I wear a pair of mechanics gloves to remove and re-install the filler cap.
You need to take several readings with the dipstick and this mod allowed me to perform this easily and quickly.
Try and take this dipstick in and out several times with just your fingers, even with gloves on, and you will soon be giving a verbal whipping to the FoMoCo engineers.
This mod keeps the dipstick positioned perfectly so it does not fall over or tilt, which could give you a false reading on the hash mark.
---------- Post added at 11:27 AM ---------- Previous post was at 11:09 AM ----------
I did not use a lift. I just threw a piece of carpet on the ground and crawled underneath to take readings.
Just insert dipstick, remove, take reading, wipe clean and repeat until you have a consistant reading.
I'm 5'7" and maneuver quite will under the raptor for this.
A lift is preferable but the trans fluid temp was dropping below 193F quickly.
So I had to act quickly and throw the carpet down and crawl underneath, remove filler cap and perform the reading.
---------- Post added at 11:32 AM ---------- Previous post was at 11:27 AM ----------
Ruger.....Drill and tap the dipstick and attach a handle. Done.
Simple and effective.
How To: Locate the 6R80 Transmission Dip Stick BigJ Ford Raptor Maintenance Forum 14 05-20-2017 08:42 AM
Modifying Bedsides Idleone Ford Raptor Exterior Modifications Forum [GEN 1] 8 09-02-2014 10:13 PM
Modifying Corsa exhaust VAFordGuy Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 2 02-16-2014 10:16 AM
modifying the Airaid intake tube farman Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 1 03-07-2013 10:47 PM
Modifying my stock lower/AFE intake SOCOMech Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 16 04-15-2012 03:24 AM
