Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Maintenance for unused shocks
This is a discussion on Maintenance for unused shocks within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
I have searched the forum, but I have not found any threads pertaining to this particular question. If you have ...
Old 11-15-2017, 02:21 AM   #1 (permalink)
SVTFordRaptor's Avatar
Default Maintenance for unused shocks
I have searched the forum, but I have not found any threads pertaining to this particular question. If you have a Gen 1 Raptor that you stored as a collector vehicle should you do any maintenance to the shocks? It is a 14 with less than 1000 miles. I know you ought to get the shocks serviced according to mileage and off-road use; however, I did not know if the fluids would break down and go bad from simply not using it.
I am going to start driving it, so I am in the process of changing all the fluids on it (brake fluid, power steering, transmission, differentials, etc). I do not want to damage the shocks.
Thanks for your help!
SVTFordRaptor is offline   Reply With Quote
Old 11-15-2017, 04:46 AM   #2 (permalink)
downforce137's Avatar
most likely the nitrogen charge needs to be checked which will require removal, so might as well change the oil at the same time..
downforce137 is offline   Reply With Quote
Old 11-15-2017, 07:57 AM   #3 (permalink)
SZDZMTR's Avatar
Its not the best thing when the vehicle has no mileage and in your case none at all. You might have to through changing all the fluids including trans diffs ps....check out the seals and gaskets for leaks. Regarding shocks, i think just drive it and check for leaks, once its on the road, and see for yourself if the ride is normal or they feel like they need a rebuild.
2013 SCREW TUX BLACK LOADED (MONEY PIT)
2011 SCAB MOLTEN ORANGE (SOLD)
SZDZMTR is offline   Reply With Quote
Old 11-15-2017, 09:26 AM   #4 (permalink)
EricM's Avatar
It's averaged a mile a day so far if it's three years old. Change the oil and drive it- don't worry about it.
2013 Tux Black SuperCrew.
Nobody gives a crap where your post was sent from...
EricM is offline   Reply With Quote
Old 11-15-2017, 12:48 PM   #5 (permalink)
t_j's Avatar
t_j
Drive it, check for leaks, rebuild if required. Depending on the bearing and seal caps the main oil seal may have gotten to dry and cracked, but it would need to be an early production 2010 to have the susceptible o-ring instead of the slightly tougher lip seal. As for the nitrogen charge, its probably just fine and I wouldn't worry about it unless you have some leaks.
t_j is offline   Reply With Quote
Old 11-15-2017, 07:47 PM   #6 (permalink)
Dildo Schwaggins's Avatar
Junior Member
Will maintenance be required on shocks if I buy an extra set to leave on a shelf until mine need a rebuild? Or will they be good for a year or two?
Dildo Schwaggins is offline   Reply With Quote
Old 11-16-2017, 10:27 PM   #7 (permalink)
Thanks for the feedback guys!
Old 11-17-2017, 07:33 PM   #8 (permalink)
Camperguy's Avatar
Idk, theres a company that basically sell heavy duty bags you drive your truck into. Disconnect the battery, unload the suspension (jack stands) . A large dessicant pack is placed in there and you can suck it shut with a shop vac or fill the bag with nitrogen. Yes you will suffocate if you go in it. I never had enough money to keep a car as an investment but this setup looked cool. Yes it was in a climate controlled room with hepa filtration.
Camperguy is offline   Reply With Quote
50k maintenance ? QUADS2929 Ford Raptor Maintenance Forum 14 06-02-2014 04:03 PM
FS: TRR13 Stubby -- Unused Phyguy Garage Sale 6 10-07-2013 02:38 PM
Raptor never came in, now sellin unused goodies troycrna Garage Sale 17 02-14-2012 07:40 AM
Lots of Parts - All brand new and unused Chrisandalex1 Garage Sale 8 09-29-2011 05:17 PM
unused parts for sale Chrisandalex1 Garage Sale 5 07-11-2011 06:44 PM
