Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Low Oil Pressure and Wrench Light Problems!
This is a discussion on Low Oil Pressure and Wrench Light Problems! within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
Like Tree4Likes
Old 03-01-2018, 12:08 PM   #1 (permalink)
MasonP's Avatar
Junior Member
Default Low Oil Pressure and Wrench Light Problems!
Iíve been having this annoying problem happen and I donít know why. Iíll explain it best I can and maybe someone can tell me what they think it is or know it is.
I was driving down a road about 45-50mph, then I go to ďget on the gasĒ a little and speed up. Gear drops into 5th and then my throttle goes out completely and slowly drops to 0 RPMs. At this point I canít press the gas pedal, it does nothing for me, no response. Once I stopped (in the middle of the road) ďLow Oil PressureĒ light comes on and I have to put the truck in Park, turn it off, and turn it back on again, which the first ignition doesnít work, so I had to crank it again and it turned on and I drove home fine.
This happened again a previous day once when I was driving about 40mph and the ďWrenchĒ light comes up on my dash then it slowed down and the throttle response goes out slowly, then it actually kicked back in and it was fine.
If anyone has had this problem and knows how to fix it please let me know.
My mods that may have any affect are:
SCT Performance 5 Star Tune
Pedal Commander (which Iíve turned off at this point, but it happened again)
Please let me know if you know whatís going on! Thanks.
2014 White SCREW
MasonP is offline   Reply With Quote
Old 03-01-2018, 12:34 PM   #2 (permalink)
AndysLog's Avatar
telling us the codes may help.
AndysLog is offline   Reply With Quote
Old 03-01-2018, 01:31 PM   #3 (permalink)
Are you low on oil?
(really low, not half a quart or similar)
smurfslayer is offline   Reply With Quote
Old 03-01-2018, 04:25 PM   #4 (permalink)
Dane's Avatar
Better stop driving it and read the code!
2012 Black SuperCrew Roush Raptor
2015 BMW S1000RR
2016 BMW S1000RR (yes, we have two)
2008 Mercedes SLK 280
2003 Jeep Rubicon (sort of)
Dane is offline   Reply With Quote
Old 03-02-2018, 12:33 AM   #5 (permalink)
MasonP's Avatar
Junior Member
I checked for codes, didn’t get any. I’ll check next time it happens.
Old 03-02-2018, 12:35 AM   #6 (permalink)
MasonP's Avatar
Junior Member
I checked dipstick for oil, I recently just got it filled up about a month ago. Iím no professional but I donít think I have enough? I swabbed the entirety of the dipstick and all I got was this.
Old 03-03-2018, 10:19 AM   #7 (permalink)
Thatís not really the primary indicator, where was the oil level showing on the dipstick?
if youíre not showing oil in the range on the dipstick then yeah, youíre probably low. That would not be a good thing ( and, totally unacceptable for a $40,000 truck! ).
Old 03-04-2018, 01:54 PM   #8 (permalink)
Junior Member
I just had the same thing happen to me on the highway. Hit the gas, pedal dies, low oil pressure warning, and indicator shows no oil pressure but truck still runs. Stoppped put it in PArk and restarted. Rushing to a meeting so can’t mess with it but won’t go over 4K rpms while in park. Not sure if that is normal or not
Mjc123 is offline   Reply With Quote
Old 03-07-2018, 04:04 PM   #9 (permalink)
Junior Member
My 14 has done that a couple times too. Mine has only happened at very slow speeds tho. (pulling in to parking lot and backing up in driveway) I just went and got the oil changed so I'll let you know if happens again.
1FastSUV is offline   Reply With Quote
Old 03-07-2018, 04:31 PM   #10 (permalink)
Dane's Avatar
You're scaring me man...
2015 BMW S1000RR
Tags
electrical, low oil pressure, wrench
Wrench Light comes on speedometer stops workin Adub35 Ford SVT Raptor General Discussions [GEN 1] 2 01-11-2018 04:20 PM
GEN 1 Wrench Light Fodded_Cockpit Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 4 09-24-2017 11:30 AM
Wrench Light On BobboZR2 Ford Raptor Problems and Questions Forum 3 06-07-2017 03:08 PM
Cold Start Wrench Light jlauth Ford Raptor Problems and Questions Forum 24 04-27-2016 11:20 AM
wrench light Rust5 Ford Raptor Problems and Questions Forum 1 01-28-2015 08:25 PM
