GEN 1 How much brake fluid needed for flush?
KingRoman
Ordered new brakes all around and stainless lines, however only have 3 bottles (500ml) of RBF600 and now I'm 2nd guessing if I should get more.
Thanks
BenBB
Lots of different places
Thanks
Unless you hear otherwise from someone that's changed the lines, I'm pretty sure you'll have plenty. I installed some speed bleeders and bled as much of the original fluid as I could and barely used over a quart (946ml). BTW those things will make bleeding a whole lot easier, well worth it I think.
