HELP where is the drain plug for the radiator
JimT
Tulsa, OK
I want to change the coolant on my Raptor but can't find where to drain the fluid.
JimT
JimT
Tulsa, OK
Passenger side bottom corner of the radiator. It's red and you'll probably have to loosen with pliers.
Thanks OUTCAST, I found it. Actually a wide straight slot screwdriver works nicely. There is a slot for it in the center of the plug. :waytogo:
