Wilson
I would also recommend knowing the coast of your dealer doing an oil change for you at WatertownFordChrysler labor is under $10 and thy check every thing out for you so at that price I bring it to them.
I will post a video later on how to replenish the windshield washer fluid.
when you put an oil on the new oil filter its messy, is it ok not to put an oil on the oil filter?
It helps it get a better seal. Whenever I change oil, I always wear either latex or rubber gloves. Once you have the oil drained and the old filter out just dip your gloved finger into some of the old oil and rub it around the rubber seal on the new filter. This ensures a tight seal with no leaks. And it's not messy at all.
sorry i meant filling the new oil filter with oil as opposed to dabbing oil onto it.
