Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Sponsored Ads
Cheapest Oil Change and done RIGHT!
This is a discussion on Cheapest Oil Change and done RIGHT! within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
Register to remove these ads. It's free! Originally Posted by Ruger Same here. Yep. Pretty much they all do near ...
Old 10-21-2011, 10:30 PM   #11 (permalink)
Phyguy's Avatar
Originally Posted by Ruger View Post
Same here.
Yep. Pretty much they all do near me (Napa, Autozone, Advance Auto Parts, etc). I use this pan too...pretty non-messy:
Blitz USA 11865 11 Qt. Mess Buster Oil Drain
"Everything should be made as simple as possible, but not simpler." -- AE
2011 Tux Black SCREW Loaded - #5173 out of 11135
Phyguy is online now   Reply With Quote
Old 10-29-2011, 09:58 AM   #12 (permalink)
I got a mityvac pretty cool way of changing oil. I used it a lot on my z06, it was to much work to change the oil since it was so low. For anyone thats lazy like me its a must.
Ryguy84 is offline   Reply With Quote
Old 10-31-2011, 01:27 PM   #13 (permalink)
AdkRaptor150's Avatar
I've done all my oil changes on all the cars and trucks I've owned. Even in the dead of winter im out there- I like the peace of mind that I know it's done right. Especially with a truck worth this much. Not only do you get your oil changed you may see some other trouble areas or leaks which you can attend too.
2011 White SuperCab-"The Shark"
Airaid Synthamax Non-Oiled Intake WithPrefilter/Undercoat/Rhino line Bed &
Wheel Wells/GT Covers & Weathertech liners.
AdkRaptor150 is offline   Reply With Quote
Old 02-14-2012, 07:16 PM   #14 (permalink)
Airborne06's Avatar
Junior Member
Default Oil change
Just got my 2012 SCREW, and like many on this board, I've had bad luck letting dealers/lube places perform simple oil changes: The work not being done; the wrong oil being put in; filter not being changed, etc.
So...how hard is it to change the oil on the Raptor? The vehicle is so high, seems I can crawl underneath with no problem. Do I just take off the small access plate on the skid plate to reach the drain bolt? I guess I could go crawl around the vehicle and figure it out, but thought I'd take the lazy way and just ask! I may do my own oil changes, and just let the dealer rotate the tires (after I mark them first).
Thanks for any info you can provide!
Airborne06 is offline   Reply With Quote
Old 02-14-2012, 08:19 PM   #15 (permalink)
Most dealers I have tried are horrible, and do poor quality work.
I do it all myself, or have a good independant shop do work I may not be able to perform.
If you have a good dealer, count your blessings.
Drewa is offline   Reply With Quote
First self oil change comments Madcowranch Ford Raptor Tech Forum 27 07-24-2011 10:51 PM
Simple oil change, NOT ! cleveland plasma Ford Raptor Maintenance Forum 4 07-23-2011 07:36 PM
A big change coming Seeker New Member Check-In 32 06-14-2011 06:12 AM
My oil change suggestion. BIRDMAN Ford Raptor Maintenance Forum 34 06-07-2011 10:56 PM
Fully Driven Auto Network
