Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Sponsored Ads
Broken Axle
This is a discussion on Broken Axle within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
Register to remove these ads. It's free! I was reading the Sean Hyland Motorsports webpage on the GT500 motor and ...
Old 04-14-2010, 05:44 PM   #1 (permalink)
MagicMtnDan's Avatar
Default Broken Axle
I was reading the Sean Hyland Motorsports webpage on the GT500 motor and new tranny they put into the Raptor when I came across their mentioning they broke their left (rear) axle.
Left rear axle broke at the end of the splines on the last test day.
It was during this testing that we broke the left rear axle shaft, which frankly surprised us, as the HD rear axle in the Raptor has proven durable in other applications. We suspect the additional grip of the general tires, may have caused a flawed part to break, otherwise we will have to investigate some alloy axles for use of this truck.
They were running a LOT of power (600HP) and they went to Grabber tires
Now it's putting out a claimed 750HP thanks to the upgraded the supercharger to Kenne Bell unit, at 15psi on 93 octane!!!
The reason this is here in the Maintenance Forum is because I heard about a stock Raptor that broke a rear axle out in Ocotillo Wells (it wasn't just Sean Hyland that broke one) and I thought I'd post this here and see if the owner wants to comment about any similarities (or differences besides the huge HP gap).
Source: http://www.seanhylandmotorsport.com/..._testing.shtml
2010 Ford F150 SVT Raptor in Tuxedo Black fully loaded plus: 20% tint all around; Bakflip HD bed cover; Bedrug; WeatherTech Floor Liners; V1 detector w/Great Lakes mount & Invisicord; Phillips X-Treme Power bulbs; customized exhaust (removed from axle back); CravenSpeed antenna; Recon Line of Fire; Rigid 20" LED lightbar & 2 pair of Duallys; rear Amber Dually light
MagicMtnDan is offline   Reply With Quote
Old 04-14-2010, 05:52 PM   #2 (permalink)
SVTRay's Avatar
Hey Dan, was that other broken axle on a factory 5.4L Raptor?
SVTRay is offline   Reply With Quote
Old 04-14-2010, 05:54 PM   #3 (permalink)
BigJ's Avatar
The Dude Abides
Yep.
BigJ is online now   Reply With Quote
Old 04-14-2010, 05:55 PM   #4 (permalink)
frogslinger's Avatar
Yeah... one of the users on Z broke their axle four wheeling...
SVT did some research and I believe made a minor mods to later build trucks...
frogslinger is offline   Reply With Quote
Old 04-14-2010, 06:17 PM   #5 (permalink)
Yup. We know whose Raptor it was. He's a member here (used to be a member on the RuinedForumz) and he'll probably show up here since I "called him out" :mrgreen:
How do you know this? Where did you hear it? (Thanks)
Old 04-14-2010, 06:21 PM   #6 (permalink)
I heard it on the Z, hence the modifier... not sure it is factual (the mod part... the research part was fairly widely commented upon).
Old 04-14-2010, 10:50 PM   #7 (permalink)
pirate air's Avatar
will plunder your booty
Theres been a 3rd reported axle shaft failure. Its over on ************, happened over the weekend I think. Raptorguy21. Pictures look similar to the SHM break.
pirate air is online now   Reply With Quote
Old 04-14-2010, 11:00 PM   #8 (permalink)
SVTRay's Avatar
Now is this the same rear end used in the earlier Ford trucks like my 03'?
Old 04-14-2010, 11:13 PM   #9 (permalink)
pirate air's Avatar
It's a 9.75, yours should be the same. The Raptor one is longer/wider, the tube is thicker, and the axle spline count is higher (can't remember 33 spline?). Generally these axles and assemblies are very stout and do great in just a regular F150 application. There must of been a bad batch made......
Old 04-15-2010, 10:49 AM   #10 (permalink)
KaiserM715's Avatar
Super Moderator
I think these maybe 34 spline... Thought I read that somewhere.
'10 Raptor - '08 G8 GT - '67 Jeep Kaiser M715
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Fully Driven Auto Network
