Break caliper grease
98infinity
What are you guys using for a brake caliper grease, slide pins and back side of the pads?
Deleted member 12951
My slide pins were so damaged from being seized inside the hole that we had to drill it out. I purchased replacement ones from the dealership (less than $20) and each kit came with a packet of grease. There is more than enough for one guide pin so I used that stuff.
TheJoker
N. E. Massachusetts
I bought this, thinking that I would do the brakes myself. Ended up giving it to my mechanic to do.
ramx50
Wakefield, MA
I have always used Sil-Glyde on all the brake jobs I have done over the years.
This is great stuff!
http://www.google.com/aclk?sa=l&ai=...=&ved=0ahUKEwiD6JW479zOAhWODBoKHWtzCAgQwjwIDg
---------- Post added at 11:25 AM ---------- Previous post was at 11:22 AM ----------
Some people use anti seize.
I would not use this on the slides, it will partially dry out causing more friction than you want.
