Battery replacement recommendations
ISFast
Tulsa, OK
Yeah if you get an optima get a Yellow top. The Blue and the red i haven't had near as good of luck with.
Budget1
RivCo, CA
I've yet to run an Odyssey in a vehicle, but I have them in my PWC's. They are incredible. Tons of abuse and they still hold a charge. No leaking. You can mount them how ever you want. Nice stuff
Badgerscab6.2
Fox Valley, Wisconsin
I swapped out for the red top that was in my old truck before I got rid of it a while back. I think a blue top would be the best choice though for this truck. Its made for marine use so its deep cycle (they do make blue starting too, black case). but because its for marine use, it has more vibration resistance and has 1/4 or 3/8 + and - posts for accessories
Smokinjo
Germantown Tennessee
Noah
I sent you a PM about battery question.
I have three Tsunami 2150's in my boat. Time for replacements. Don't want to break the bank though. Boat is MB B-52 23V. PCM ZR6 motor, Audio is 6000 watts with 5 12 inch subs, 8 amps, and multiple other speakers. It was custom by Tim at Wet Sounds. Any advice. It's not my truck that needs replacing yet.
Thanks
Boss Hoss
Colleyville, Texas
The Sears is a AGM made by the same folks who build that type for the USG! Optima is a different set up than the AGM and has more problems plus will not last as long. Don't want to get too far in the weeds here but AGM is the way to go for what you look for in a battery. Plus the Optima used to be pretty common around here but no so much anymore. When you do find them most have been sitting in the shelf somewhere for a longer period of time than I will accept.
Dv8tor
Detroit, MI
The red, for what I was told is for performance starting for high compression engines . Yellow is for lots of accessories like lights or sound systems. Blue is for boats.
