76k Mile Maintenance Questions?
SZDZMTR
Sewell, NJ
Here is the PDF of the TSB
http://m.ford.oemdtc.com/TSB/15-0137.pdf
Basically fuze 27 socket starts to melt and fails. It's for your gas pump in the tank. Once blown, can't start truck and been known to kill engine while driving. In the PDF, shows part number. I got mine from Tascaparts.com. The kit relocates Fuze 27 to socket 70 and supplies a different bigger fuse as it should have been from factory.
thank you. i will call ford and torture them tomorrow. And i will contact Tascparts. Thank you again
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
I hit 76k miles on my 2013...and I'm going to have some maintenance done. All that I've done is air filter, regular oil changes and tire rotations.
What would you all suggest?
Here are my product recommendations:
1). Coolant flush - https://www.amsoil.com/shop/by-prod...ity-antifreeze-and-engine-coolant/?zo=1678239
2). Front and rear differential fluid -
Front - AMSOIL Severe Gear® 75W-90
Rear - AMSOIL Severe Gear® 75W-140
3). Trans flush - AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid
4). Power Steering Fluid Flush - AMSOIL Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
5). Transfer Case - Same as the Power Steering Fluid
6). Brake Fluid - AMSOIL Series 600 DOT 4 Racing Brake Fluid
7). New Brakes - Use Promo code BLACKFRIDAY20 for 20% off R1Concepts full package here -- https://www.freedommotorsportsraptorstore.com/index.php?main_page=index&cPath=1126_1128_1370
