02-20-2012, 01:54 PM
#6 (permalink)
Use your intuition. If you're winching out of something either forwards or backwards, drive and park are ideal. If you're winching someone out, park, drive, and reverse are all ideal depending on the situation. If you figure that park is the the best, make sure you put the parking brake on as well.
Nevertheless, your transmission shouldn't be on the top of the "things to worry about list." I'd be more worried about steering components such as a broken tie rod or something.
//EDIT// Whoops! Can't believe I told you to winch yourself out in drive or park...
The bold part should say: If you're winching out of something either forwards or backwards, drive and reverse are ideal.
