Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Forum General Discussions > Off-Roading Your Raptor
Sponsored Ads
winch
This is a discussion on winch within the Off-Roading Your Raptor forums, part of the Ford Raptor Forum General Discussions category!
Register to remove these ads. It's free! is there any portable winch which you just instal when you need and ...
Old 02-02-2012, 09:07 PM   #1 (permalink)
Default winch
is there any portable winch which you just instal when you need and move it when you dont want?
uaq69 is offline   Reply With Quote
Old 02-02-2012, 09:13 PM   #2 (permalink)
All The Way's Avatar
Aus nichts wird nichts
I'm using the Wicked front receiver mount and waren cradle with a M8000
Dirt is for Racing.
Asphalt is for getting there.
http://www.youtube.com/allthewayii
All The Way is offline   Reply With Quote
Old 02-03-2012, 04:49 AM   #3 (permalink)
I think it can be used in rear as well? From where you buy this and is ready you just connect it and switch it on
Old 02-03-2012, 06:45 AM   #4 (permalink)
BigJ's Avatar
The Dude Abides
I decided on a Power Puller. See here for the discussion: Why not a come-along?
BigJ is online now   Reply With Quote
Old 02-03-2012, 05:17 PM   #5 (permalink)
Yes you can use it in the rear but you will have to run power back there.
I take some better pictures.
Dirt is for Racing.
Old 02-04-2012, 05:48 PM   #6 (permalink)
Here is the power plug tucked away in the front of the truck
Plug cap zip tied down so it doesnt bounce.
Dirt is for Racing.
Old 02-04-2012, 08:03 PM   #7 (permalink)
thank guys for the helpful information's
Old 05-14-2012, 02:52 PM   #8 (permalink)
Junior Member
Wow, that looks really clean. Any chance there is a closeup pic of how it mounts? What is the load rating with that?
xtcbct is offline   Reply With Quote
Old 05-14-2012, 05:08 PM   #9 (permalink)
GJMcManus's Avatar
Smarcastic sparky
All the way, in no way I am bashing your setup... With a hitch mounted winch, couldn't you easily have more pulling force than the hitch rating? Especially, if the truck was bogged down in mud, which increases the pulling resistance. Or pulling at an angle, because most anchor points are rarely straight ahead or behind stuck vehicle. I like this setup because your not stuck with a winch in the front.
Here is what Bill Burke says about them and why I am questioning your setup..
" All class three (class III) hitches are DOT (you know them) rated at 5000 pounds. You just put a 9000 or 8000 pound rated winch in a 5000 pound hitch. Now you're going to try to pull a 6300 pound vehicle out of the mud that has a resistance force equal to or exceeding the weight of the vehicle. And you're going to do all this from a dinky 2 1'2 inch tube bolted to your frame probably with grade 5 hardware. AS IF! Never mind if you have to pull off angle cause you don't own a Pull-Pal
. I suggest that if you want to use the receiver type winch, which is actually a good idea for total function, you mount two channels front and rear and make the winch mount frame the same, thereby doubling the strength of both the hitch and the winch, and leave the single receiver for the boat or the sleds!"
-Greg
5star tune X3 | AFE stage 2 cai | Recon smoked tail lights | Recon smoked third brake light | Bakflip F1 | Craven stubby | Weathertech | Jimmi jammer gate keeper & hood latch protector | Ducati's custom blacked out 35w bi-zenon projector headlights! | Easydown tailgate | Bedrug | 315/70R17 Goodyear DuraTracs | ATX Artillery Teflon Black 17x9 -12mm | Swaybar removed | RPG stage 3 rear kit | RPG BLACK tie rod | RPG Raceline 1.5" UCA |
GJMcManus is online now   Reply With Quote
Old 05-14-2012, 05:41 PM   #10 (permalink)
012BLUESVT's Avatar
Jumpin Joe
Alltheway, For others looking to add the portable winch, can you share some information about it?
Approximately, how much was the setup?
What is the setup rated for?
How heavy is the winch set up ( for carrying purposes)
Where do you store the winch while offroading?
Thanks for the info.
2012 blue SCREW | Extang solidfold | spray in bed liner | weathertech floor liners | rear gun rack | Rustproofed | Teflon Paint Protection | PDP flaps | 75% tint | RPG Stage 4 | Fox 3.0 Front Shocks | RPG Tie rods
I love Raptorwifey
012BLUESVT is offline   Reply With Quote
WINCHES - What's a Winch? Why a Winch? When to Winch? All About Winching BigJ Off-Roading Your Raptor 7 02-12-2012 02:39 PM
Looking for winch xBX Off-Roading Your Raptor 13 05-31-2011 10:24 PM
Recon Winch Moabman Ford Raptor Exterior Modifications Forum 6 04-09-2011 01:42 PM
which size winch neveo Ford Raptor Exterior Modifications Forum 8 03-12-2011 07:30 AM
WINCHES - What's a Winch? Why a Winch? When to Winch? All About Winching MagicMtnDan Ford Raptor Exterior Modifications Forum 7 03-14-2010 04:44 AM
Fully Driven Auto Network
