Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Off-Roading Your Raptor
Steering off-center after offroading
This is a discussion on Steering off-center after offroading within the Off-Roading Your Raptor forums, part of the Ford Raptor Forums - General Information category!
Originally Posted by AndysLog These lock your bottom in correct? How do you adjust if it’s locked in place ? ...
Like Tree12Likes
Old 10-18-2017, 12:20 PM   #11 (permalink)
MatMan's Avatar
Originally Posted by AndysLog View Post
These lock your bottom in correct? How do you adjust if it’s locked in place ? Curious if you don’t have aftermarket uppers you are basically just raw dogging it
They're not permanently locked as they use nylock nuts.
During the alignment, they loosen or install the alignment cams (correct they lock the bottom bolts/nuts), make the adjustment, then tighten the bolts. There is very little chance they can slip or get knocked loose because they're cammed against themselves. Great way to prolong/secure your alignment + bombproof.
Upgraded UCAs aren't necessary to use these cams, but to your point the stock UCAs have more play which isn't exactly good.
MatMan is online now   Reply With Quote
Old 10-18-2017, 01:17 PM   #12 (permalink)
dude1782's Avatar
Originally Posted by MatMan View Post
I had an off center steering wheel after alignment once and simply took it back for them to adjust, took them 10 min.
That alignment shop just could not get it right due to lack of the right alignment technology. So I took it to the dealer and for $160 they nailed the alignment and it's been good ever since. My point is, it may just be a simple adjustment. Try Ford if you haven't already.
It was aligned at ford. Unfortunately I didnít have time to leave it with them and I havenít been able to take it back yet.
Sent from my 2017 Raptor using Tapatalk
2017...Shadow Black...SCREW...802A...Tech Package...Tailgate Step
AZRR Racin' to the Basin...June Raptor Assault...AZRR Four Peaks...ROC Pismo
Custom SDHQ Bumpers...BD 40" High Power and XL80s...Full Race IC...Eibach Springs...Deaver +3s...37" BFG KO2s...Black 17" WE Beadlocks...PCI Radio...GPS
Dude's Build Thread
dude1782 is online now   Reply With Quote
Old 10-18-2017, 04:00 PM   #13 (permalink)
AndysLog's Avatar
ok, i was under the impression the kit locked your lower settings into one specific spot and no adjustments could be made. thats neat.
AndysLog is offline   Reply With Quote
Old 11-10-2017, 01:24 PM   #14 (permalink)
78 DESERT RAT's Avatar
Junior Member
I had the same issue after each time driving hard off-road, alignment would be off every time. I got tired of taking it back to the alignment shop, so I took a trip to the dealer and talked to one of the mechanics who I was told was the "Raptor Guy" he told me to purchase these certain alignment cams off of Amazon and bring back and he would install. I did what he said and haven't had a problem since.
kevin85 likes this.
78 DESERT RAT is offline   Reply With Quote
Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade ICONRep ICON Vehicle Dynamics 64 03-23-2016 11:55 AM
Steering wheel not completely on center. estrader Ford Raptor Problems and Questions Forum 7 11-14-2014 12:43 PM
steering wheel center after mid perch mod nsdq3 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 40 05-17-2014 12:48 AM
Steering wheel off center fish27 Ford Raptor Problems and Questions Forum 10 01-12-2014 06:56 PM
TSB 11-12-11 - Lack of steering assist or excessive steering effort pirate air Ford Raptor Recalls | TSB's | SSM's 0 05-16-2012 03:51 PM
