Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Off-Roading Your Raptor
Steering off-center after offroading
This is a discussion on Steering off-center after offroading within the Off-Roading Your Raptor forums, part of the Ford Raptor Forums - General Information category!
Hi all, so I took the raptor offroading and got some air time. I noticed now that when the truck ...
Like Tree13Likes
Old 10-17-2017, 12:19 PM   #1 (permalink)
Default Steering off-center after offroading
Hi all, so I took the raptor offroading and got some air time. I noticed now that when the truck is going straight, the steering wheel is off to the right a little bit. I just got the truck aligned not long ago, is this an alignment issue? or could be something else. I took a look at spindles, LCA, Tie-rods, nothing seems to be bent or damaged. Thanks
2014 OW Screw.
Mods: Method NV 17". Icon Bump Stop. Icon Rear Leaf Springs. SVC Front/Rear Bumper. SVC Bypass Rack. Fox 3.5 18" Bypass Rear. Fox 3.0 Front. 30" Rigid. Rigid D2 fogs. Rigid D2 Hyperspots. Icom VHF Radio. Lowrance HDS7m
kevin85 is offline   Reply With Quote
Old 10-17-2017, 12:21 PM   #2 (permalink)
AndysLog's Avatar
offroading loves to eat alignments. if you can find a shop that has a 6month alignment agreement. take it back after every adventure.
kevin85 likes this.
AndysLog is offline   Reply With Quote
Old 10-17-2017, 12:32 PM   #3 (permalink)
SZDZMTR's Avatar
^^^^ what he said. Just play dumb when you go back. lol
kevin85 likes this.
2013 SCREW TUX BLACK LOADED (MONEY PIT)
2011 SCAB MOLTEN ORANGE (SOLD)
SZDZMTR is offline   Reply With Quote
Old 10-17-2017, 01:03 PM   #4 (permalink)
Aaron's Avatar
Meme Corps Commandant
This was simply your truck calibrating itself to the offroad terrain. If the steering wheel wants to hang to the right, who are you to tell it that it should straighten up?
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 10-17-2017, 07:48 PM   #5 (permalink)
thanks guys, maybe I should get the firestone lifetime alignment
2014 OW Screw.
Old 10-17-2017, 09:25 PM   #6 (permalink)
MatMan's Avatar
Also recommend the SDhQ alignment cams, which cam in place to eliminate or reduce any movement in the alignment settings.
kevin85 likes this.
MatMan is offline   Reply With Quote
Old 10-18-2017, 01:17 AM   #7 (permalink)
dude1782's Avatar
Kekstani Freedom Fighter
Something in my power steering is broken somewhere. I have to take it in so they can figure out what's wrong and fix it. I put on a lot of off road miles and took it in to get an alignment and after they got it aligned and driving straight, the steering wheel was pointing right. However, I did get under it and look around and didn't see any damage.
"The world must learn our peaceful ways, by force!" - Grand Shepherd Bender Bending Rodriguez
dude1782 is online now   Reply With Quote
Old 10-18-2017, 09:59 AM   #8 (permalink)
Raven13's Avatar
After Raptoberfest my steering wheel calibrated itself to the left, part of off-roading!
kevin85 likes this.
Raven13 is offline   Reply With Quote
Old 10-18-2017, 11:36 AM   #9 (permalink)
MatMan's Avatar
Originally Posted by dude1782 View Post
?..put on a lot of off road miles and took it in to get an alignment and after they got it aligned and driving straight, the steering wheel was pointing right. However, I did get under it and look around and didn't see any damage.
I had an off center steering wheel after alignment once and simply took it back for them to adjust, took them 10 min.
That alignment shop just could not get it right due to lack of the right alignment technology. So I took it to the dealer and for $160 they nailed the alignment and it's been good ever since. My point is, it may just be a simple adjustment. Try Ford if you haven't already.
kevin85 likes this.
Old 10-18-2017, 11:48 AM   #10 (permalink)
AndysLog's Avatar
These lock your bottom in correct? How do you adjust if itís locked in place ? Curious if you donít have aftermarket uppers you are basically just raw dogging it
Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade ICONRep ICON Vehicle Dynamics 64 03-23-2016 11:55 AM
Steering wheel not completely on center. estrader Ford Raptor Problems and Questions Forum 7 11-14-2014 12:43 PM
steering wheel center after mid perch mod nsdq3 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 40 05-17-2014 12:48 AM
Steering wheel off center fish27 Ford Raptor Problems and Questions Forum 10 01-12-2014 06:56 PM
TSB 11-12-11 - Lack of steering assist or excessive steering effort pirate air Ford Raptor Recalls | TSB's | SSM's 0 05-16-2012 03:51 PM
