Deleted member 12951
See I am starting to think if I want to switch to beadlock then I need air from 0 psi. Will a 10# C02 tank be enough?
Sent using Tapatalk
Sent using Tapatalk
No. I don't have bead locks. I only air down to 25-30 PSI. No need to go lower here in lovely SoCal
Uh, let's put it this way, it depends on the terrain and speeds. On rougher (rocky) terrain at lower speeds you will want to go lower.
jack doesn't drive at higher speeds
I've used my onboard system a lot since installing it and love it! Talk to Chris at freedom motorsports to get the differences between the different systems he's a genius when it comes to this lol
http://www.fordraptorforum.com/f11/viair-onboard-air-how-29451/
