Air Gauge / Tire Inflator Recommendation?
  • Start date
I purchased a C02 tank and Air Compressor. I am now looking for recommendations on an air gauge tire inflator to use with it. I would prefer one that could work with both and that has a lever to depress to let air pass. Both units came with one. The C02 is just an air chuck and I would have to use a separate air gauge. The air compressor has a air gauge but no lever. Each other doesn't work with each other.
I purchased these items:
Smittybilt Part 2781 - 5.65 CFM Air Compressor-RH1
Smittybilt]-RH1 Part 2747 - Compact Air System-RH1
Here is a picture of what they both look like. The ARB tire deflator is in the pic too that I will be using.
Any suggestion would be greatly appreciated. TIA!
Thanks. I am holding off purchasing it as I like the Powertank ones better but they cost 3 times if not more.
