Bought my 12 in 14 with 30K miles, now it has 67K and I'm collecting parts for a light duty build.
I'd like to list what I have so far, and see if you guys have any suggestions on what to add to make it better or more complete.....or one of those 'since you are in there, you may as well.....' type things. This is my daily driver, so I hope to not have the truck down very long when doing this stuff.
Previously done mods:
Raptor retrofit 14 headlight upgrade
mini antenna
generic square lights in stock bumper cutouts
Stuff I have, or is on the way for suspension:
Front and Rear Fox 3.0's
RPG Stage 2 Brace and Bump stop kit
WSI HD Springs
Ready Lift Upper A-Arms
SVC Lower A-Arms
18" Method Standards with 35" Toyo R/T's (starting to think I should have gotten 37's)
Alpha 1 tie rod ends
IWE elimination rings
Under hood Mods:
Stainlessworks Full headers and exhaust
AFE Intake
RPG powersteering reservoir
deraile small PS cooler
FMC Transmission cooler upgrade
Truck will be custom tuned by Beyond Redline Performance in Green Bay
Body/Looks/electrical
SVC Baja bumper with visionx lightbar
camera modification module thing to turn the cams on at will
So, a few mods, but nothing like what most of you guys do. Will the 35's look stupid on this setup? When I ordered them, I figured I'd stay the same as stock. I don't have them yet, but I don't think the order can be changed.
Should my axle seals, wheel bearings, and any other retained stock suspension pieces be fine? Any recommendations on brakes? This is my first Ford ever, I'm not certain what the 'weak' points are, other than the stupid IWE system that I had fixed once already under warranty.
Thanks, and I'll try to update with pics as I do this.....once all the parts are here.
Anyone in SE Wisconsin that have done some of this stuff want to join? I will be having some BMW friends up to help, but we are all fordtarded, working on German sedans is little prep for this stuff, haha.
Here is what is sitting in my shed now.
mini antenna
WSI HD Springs
SVC Lower A-Arms
Under hood Mods:
AFE Intake
