Resurection!! Bringing a totaled Raptor back from the dead!
Bullishone
Really dumb question, how old is the gas? I'm assuming it's a fresh tank? How about the oxygen sensor?
By the way you truly amaze me. I could never do this.
R
REBELx504
New Orleans
fresh 93 in the tank...
did have an O2 sensor giving weird readings...I actually replaced that this morning...now reading correctly, but did not correct problem...
might be a intake gasket leak from the accident...trying to locate a smoke machine now...
R
REBELx504
New Orleans
OK... no vacuum leaks.
Three different techs from three different Ford stores all said "BAD THROTTLE BODY" ... so I ordered one today...be here on Wendesday...keep ya posted...
R
REBELx504
New Orleans
so, the throttle body did not fix the issue...tech at ford that was with me said change the RCM (restraint control module), the truck may think it is still in the accident and shutting off the fuel pump...maybe...
svtraptor13
Wisconsin Rapids, WI
Check fuse #27 under the hood see if it's getting melted. That is the for the fuel pump.
