Imdubious' Raptor Build
imdubious
imdubious
Broussard LA
Ok the modding is starting up again.
First thing done was tires
imdubious
imdubious
Broussard LA
Then order a add venom front with winch and a custom one off light setup.
This is still a few weeks out. So pics to follow
Next I started ordering a full audio system upgrade
Front Door: JL Audio C5-570
Rear Door: JL Audio C5-570X
Amp: JL Audio HD900/5
JL Audio CL441dsp: CleanSweep® OEM Audio Interface with Automatic Digital EQ
JL Audio CL-SSI: CleanSweep® Signal Summing Interface
Stinger SK6241 6000 SERIES 4 GAUGE POWER WIRING KIT
Stinger 12 Ft 4-Channel 8000 Series Audiophile Grade RCA Interconnect Cable
2 roll Focal B.A.M XXXL Dampening matt (thanks Noah)
Stinger HYPER-TWIST 16 GAUGE SPEAKER WIRE 250'
I'm still up in the air on the sub but it will be under the Back passenger seat.
The two top candidates at the moment are:
JL Audio 10TW3-D4
Alpine SWR-T10
Ill probably run one of my alpine Type R 12" I have laying around till I either build a box. or brake down and let Noah do it. Depend on how tired of car audio work I am after I install every thing. Noah if you something I missed let me know so I can order it before I tear the truck apart.
Audio stuff it starting to Show up!
imdubious
imdubious
Broussard LA
This is my $20 home Depot Bed sag MOB! 3/16 cable and a turn buck sucked my top gap in over a 1/2" total
aka grumpy car stereo guy
it looks like you got everything covered. the alpine swr is a good speaker, but a bit overpriced if you ask me. as an authorized dealer for both jl and alpine, my preferance is a jl (based on the money) you wont get the performance you would expect with the swr price tag. it will be a little better than the jl, but for $300 more. i personnally dont think its worth it. but if you do want the little extra output, then go for it, alpine makes a good woofer. as far as a box goes, i have a design for a single 10 under the 1/3 section. it uses 2 of the oem sub brackets that get fiberglassed into the box and a 3 bracket that gets mounted under a seat bolt. i can help you design one, or i can build it for you. just let me know.
1 more thing. the hdrlc. jl audio bass knob for the amp. you can use it to control the sub volume without having to adjust bass on the whole system. you should run the wire along with all your other wires.
