2013 Roush Stage 2 Expedition Raptor Build
Reno, NV
Roush Stage 2 Supercharger, Exhaust, Graphics, Headrest, Boost Gauge
SCT Livewire TS, 5 Star Roush Tune
Icom ID-5100A 2m/70cm Transciever with Diamond K400C Mount and NR-770HB Antenna
Passport 9500ix with BlendMount under mirror
Proclip Electronic Mounting Hardware
Ford Remote Access
Ranch Hand Push Bar
Icon Vehicle Dynamics Lower Arm Skid Plates
Rigid Industries E-Series 28" 20" and 4x D2
Retrax PowerTrax Pro Tonneau Cover
Yakima Custom Bed Rack
CVT Mt. Bailey Roof Top Tent
Warn 87310 9.5xp-s with Multi Mount Carrier
PIAA 19983 D3S Alstare HID Bulbs
LED Reverse and License Plate Lighting
Front and Rear WeatherTech Floor Mats
DU-HA Gun Rack
Dee Zee Tailgate Assist
AndrewLeeGeorge
Reno, NV
Warn sells cables that you can run from the battery along the frame to the rear for a quick disconnect solution. If you also get the quick disconnect jumper cables you can jump start vehicles and power devices like an electric trap thrower when you go shooting without having to open up the hood.
Amazon.com: WARN 32966 24' Quick Connect Power Cable: Automotive
Bigg50
Vallejo, CA
Question - the mounts that hold the cross bars, are they easily removed from the tracks?
Truck looks great btw.
AndrewLeeGeorge
Reno, NV
The roof rack bars on the bed are easily removable and can be adjusted to any position on the track. In the photo you can see the Yakima rails are mounted on the rails of my PowertraxPRO tonneau cover. When you don't want the rack anymore all you need to do is unlock each tower with the supplied key and remove the rack. This allows you to configure the bed rack with a new configuration in 60 seconds. (i.e. switch out the CVT tent rack for a cargo basket rack with 6x 4gal rotopax fuel tanks for 24 extra gallons of fuel)
AndrewLeeGeorge
Reno, NV
Love the Gobi rack on your truck btw. I don't see it on their website so that must be a custom build. As much as I want one I enjoy being able to fit into garages when I need to
Bigg50
Vallejo, CA
Thanks for the info. Been toying with the idea of getting a RTT but need an easy way to swap from camping mode to Raptor run mode. This looks like it would do the trick.
Thanks. Gobi is getting ready to officially launch them very soon. They've been doing a sort of soft launch on them for now. You have to call to order and they take a while to build.
AndrewLeeGeorge
Reno, NV
Hey @AndrewLeeGeorge, you don't happen to have the part numbers or links for the Yakima setup?
The following links will take you to every part used in the bed rack setup.
Keep in mind the Yakima Control Tower Tracks install cleanly on my bed because they are mounted flush to the rails of a Retrax Powertrax Pro Tonneau Cover which has a 1/4" foam layer underneath its rails allowing it to conform to the plastic ridges on the Raptor bed rails. If you do not intend to have a Retrax Pro underneath the Yakima rack, a similar foam layer should be added to conform to the plastic bed rails.
Amazon.com : Yakima Control Tower Roof Rack Tower (Set of 4) : Sports & Outdoors
Amazon.com: 66" Yakima Roof Rack Round Crossbars: Sports & Outdoors
Amazon.com: Yakima Control Tower Tracks with Bolts (60-Inch): Sports & Outdoors
Amazon.com : Yakima SKS Lock Cores for Yakima Rooftop Car Racks (4-Pack) : Bike Car Rack Accessories : Sports & Outdoors
Amazon.com : Yakima End Cap : Yakima Railgrab With : Sports & Outdoors
Amazon.com: Yakima Landing Pad 1 for Yakima Control Towers: Sports & Outdoors
