Traction Issues
Phil_A.
Central Pa.
I have a problem. It's a nice problem to have, but it's still a problem.
The 6.2L engine makes so much low-end torque that, anytime the road is wet, I either have to feather-foot it away from a light or engage the rear e-locker. If I don't, I will get tremendous wheelspin from one wheel because of the open diff. And even if I lock, I still get chatter and bucking.
Why didn't Ford use something like the Ected diff., which is a limited slip when unlocked and a spool when locked? Fully open or fully spool may be OK for pure off-road use, but is downright dangerous on the street and does not allow me to use my engine hardly at all. Does anybody know of a different (aftermarket) setup that might work better on the street and retain selectability?
Or maybe it's the BFG tires (which, unlike most of their ATs, is not severe-snow rated). Would going to a different tire get me better wet traction? Any suggestions?
NY SCREW
new york
dosent the torsen diff change this problem on the 2012's i know this doesn't help you but could be fords fix to it
SoSmoked
changes his exhaust setup more than his underwear
Yup I've nearly slid into a center divider covered with trees from cornering too quickly. It's a good problem
Ms. MI Raptor
FRF Lady
FRF Lady
Marquette, MI
Same problem here... I just hope it goes good thru snow because the flakes have already started falling. I'm getting new tires under warranty so maybe some fresh, soft rubber will grip a little better than the dry rot ones I have now do - probably wishful thinking tho!
Sent from my iPhone
Raptorguy21
The Bob Vila of Trucks
Hell Paso
If I'm not mistaken, but I've been known to be, isn't the rear diff suppose to "act like" a limited slip when the locker isn't engaged???.......in which case your one wheel peel might be a problem.....
swoop1156
USA
Yeah, mine locks up all the time when I am in sand or dirt. I never have problems, rain or snow, getting traction and you're just talking about when the ground is 'wet'? I don't know what you're doing, but you're doing it wrong.
You do not want to use 4HI on pavement.
You do not want to use E-Locker on pavement.
Just drive.
pirate air
will plunder your booty
I think its fun:confused: Put it in off road mode, that'll tame the throttle response down.
