Locking differential wires disconnected
AJS44
Hunterdon County NJ
In my gen 1 raptor after pulling out the locker selector I received a message saying "check locking differential." Since the message came up immediately it had to be electrical so I checked all the fuses and wires and eventually moved on to taking the diff cover off.
I found the two blue wires that are inside the diff completely disconnected and the plate they should be attached to free to spin w the tab bent.
All the dealerships tell me the only way to fix it is to replace the whole differential costing which alone is $2300. Local scrap and part yards also said they can only get the whole mechanism for about $2000.
Anyone have any thoughts on how I can fix it without replacing the whole thing?
CoronaRaptor
CANADA
I wonder if that part isn't suppose to spin free anyway? Hope some mechanic chimes in, interesting.
AJS44
AJS44
Hunterdon County NJ
I don't think it is supposed to spin as the two wires are connected to the plate. The plate also has a tab on it that is bent out which I'm assuming is meant to hold the plate in place
