Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Tech Forums > Ford Raptor Tech Forum
Sponsored Ads
Wiring back up lights to stock wires...
This is a discussion on Wiring back up lights to stock wires... within the Ford Raptor Tech Forum forums, part of the Ford Raptor Tech Forums category!
Register to remove these ads. It's free! What color is the wire in the tail lights for the reverse lights? ...
Like Tree3Likes
Old 02-07-2012, 05:43 PM   #1 (permalink)
BubbaRaptor's Avatar
Default Wiring back up lights to stock wires...
What color is the wire in the tail lights for the reverse lights? I dont want to wire my lights into a uplifter, just need em when im in reverse. ive looked around on the forum, and just need someone to help find the exact wire and the best way to get there so wires arent sticking out... Thanks!
BubbaRaptor is offline   Reply With Quote
Old 02-07-2012, 07:38 PM   #2 (permalink)
BIRDMAN's Avatar
Administrator
sorry i can't be of more help, but why not just pop off your tail light and see what color the wires are going to your reverse light bulb?
Originally Posted by 6.2 View Post
I wear Velcro shoes.
Play slow pitch softball? Check out Softball Forum !
BIRDMAN is offline   Reply With Quote
Old 02-08-2012, 10:40 AM   #3 (permalink)
puddle hunter's Avatar
Full Throttle Member
No trees were harmed in the sending of this message, however, several electrons were terribly inconvenienced.
puddle hunter is offline   Reply With Quote
Old 02-08-2012, 11:08 AM   #4 (permalink)
Ruger's Avatar
x3
You are going to have to pull the tail light housing out of the truck to do the work you want to do anyway, so it doesn't matter what color the wires for the backup lights are. They'll be readily identifiable because you know which bulb is the backup bulb, and the wires to the socket for that bulb are the ones you want.
Ruger is offline   Reply With Quote
Old 02-09-2012, 07:20 AM   #5 (permalink)
eissiendraken's Avatar
Junior Member
Cool
I have done this a couple of months ago, White w/Black strip if I remember correctly going to the backup light socket. If you can wait a couple of days I will take the light off and verify plus snap a few so you can see.
eissiendraken is offline   Reply With Quote
Old 02-09-2012, 10:03 AM   #6 (permalink)
whtrapta's Avatar
Ostrich Wrangler
You can tap into the stock reverse lights, or the middle wire in the tow plug. There are the 6 wires in a circle and 1 in the middle. Tap into the middle one.
Guys am I a douche?
[ 2010 5.4 Loaded | Black Methods | Perch Adjustment Middle | BedRug | Volant CAI | BakFlip F1 | Flowmaster 40 Side Exit | HID 6000k ]
[ Hella Aux. Back Up Lights | Cravenspeed Bullet | Sway Bar Removed | 20% Tint ]
whtrapta is offline   Reply With Quote
Old 03-30-2012, 08:57 AM   #7 (permalink)
Ranger's Avatar
I'm pretty sure the middle wire is just for rear running lights, not reverse. AFAIK there are no reverse lights on either the 4 pin or 7 pin trailer wiring.
Has any confirmed the easiest way to add supplemental reverse lights? I'd like to add some much brighter reverse lights. I just ordered a Superbumper (SUPERBUMPER Hitch Step - Stops Rear End Collision Damage.) and I thought I would somehow modify the superbumper to add some LED flood lights for reversing, so I'm looking for the easiest way to wire them up.
Ranger is offline   Reply With Quote
Old 03-30-2012, 12:17 PM   #8 (permalink)
pirate air's Avatar
will plunder your booty
The 7 pin connector does have a pin that powers reverse lights. The wire color going into the connector assembly at the back of the truck is grey with a brown tracer.
Phyguy and Ranger like this.
pirate air is offline   Reply With Quote
Old 03-30-2012, 02:55 PM   #9 (permalink)
The middle wire in the 7 pin connector is back up for sure, I have my vision x led light bars for reverse wired from there-works fine.
Ranger likes this.
sandygar is offline   Reply With Quote
Old 03-30-2012, 04:46 PM   #10 (permalink)
Ranger's Avatar
Awesome! Thanks guys, that will make my project simple.
Want your back up camera on at Red lights ! DEADEYE Ford Raptor Forum General Discussions 8 02-12-2012 03:15 PM
Back Up Lights BajaRider Ford Raptor Lighting Modifications Forum 34 07-01-2011 06:44 PM
Rigid Dually back up lights installed pirate air Ford Raptor Lighting Modifications Forum 30 12-18-2010 08:32 PM
Stock clearance lights bender5 Ford Raptor Lighting Modifications Forum 7 09-22-2010 07:32 PM
Fully Driven Auto Network
