Upgrading stock OEM trans cooler
paj1978
I will get some photos for the RPG one I have on my truck... I was pulling a 3000 pound trailer for a few hours and it worked like a charm... and it's less the deep oil pan from afe....
Super simple to install and very heavy duty....
Tmesic
Surprise , Arizona !
I cant find where RPG makes a trans cooler , only a powersteering res. Tim
paj1978
Hi Tim,
They have not put it on the website yet. But both I and Motomute were running them and they are great.
Just give them a call. My truck is at TMX so it might be a couple of days before I can get some photos of it.
SVT_4X4
Linden, MI
I just finished installing Derale p/n 15200 on my Raptor. This is a split cooler and half is for the transmission and the other half for the power steering. I used it in line with the factory coolers and mounted it down low up above where my skid plate will go on the new bumper I made. This has a puller fan and wired it to my Upfitter switch.
R1jamn
I called AFE last week and asked if they had "Will Call".
I said I would be right down to their shop and purchase the trans pan.
They said their transmission pan is still in production but that I can come down and purchase it thru "Will Call" when it does become available.
They said it will be another 7 weeks.
I really needed this pan right now.
The heat gets turned up quick here in the Southwest.
Tmesic
I just ordered the 6 row cooler that is the same as the 4 row we have , I know its not much , buts its a quick easy install and at only 65.00 shipped I will put it on my eco boost truck as I get better products for the Raptor. I am really tempted to just try the Performance Automatic pan as it's available now. Then when the AFE comes in I can move it to the eco boost. Tim
Tmesic
Where did you order it from? Link?
Again I know its only two more rows, but also it's 50 percent more than I have. At 65 dollars shipped, it's relatively inexpensive and a quick easy install. I also purchased this other cooler it holds an additional 1.3 quarts of fluid and am going to toy with trying to come up with a clean install as a secondary if it works, if not i can find a home for it on one of my company trucks.
Dorman 918 234 Transmission Oil Cooler | eBay
Aluminum Single Pass 24" Transmission Cooler Finned Street Hot Rat Rod 5 8" NPT | eBay
