IWE inspection
Madcowranch
Genetically Modified
OK
I'm getting the clicking in 4WD so I pulled one of the IWE's out. The gears look fine to me. Thoughts? Haven't looked at the other side yet.
(I'll have to post pic from my phone)
Madcowranch
Madcowranch
OK
Pic
Madcowranch
Madcowranch
OK
I think you need to pull it right out and clean it, then you might see cracks in the plastic. Maybe you have a vacuum leak?
Problem is I can't get the freaking shaft out of the hole. Can't push it baxk far enough. Think I'm gonna have to take off brake line and wheel speed sensor line.
CoronaRaptor
CANADA
Madcow, there's a thread somewhere on how to do this, I'm not your guy for that, lol. I remember seeing them pull the iwe right out and if you do that you may as well just change them anyway :). Im sure more experts will chime in.
Madcowranch
Madcowranch
OK
Be a good boy and find that thread for me, mkay?
---------- Post added at 07:49 PM ---------- Previous post was at 07:47 PM ----------
Another queastion... To replace wheel bearings you have to buy a new hub assy, correct?
t_j
Chicago, IL
Easiest way is to split the tie rod and upper control are from the knuckle. Then you should be able to pull the drive shaft then.
---------- Post added at 10:23 PM ---------- Previous post was at 10:22 PM ----------
Take the Three bolts out and pull the iwe out. Should be obvious if the plastic is cracked.
