Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Tech Forums > Ford Raptor Tech Forum
Sponsored Ads
Front Camera
This is a discussion on Front Camera within the Ford Raptor Tech Forum forums, part of the Ford Raptor Tech Forums category!
Register to remove these ads. It's free! Originally Posted by LD50 You've still got plenty of time to get it ...
Like Tree2Likes
Old 02-13-2012, 09:39 PM   #51 (permalink)
Binks's Avatar
Originally Posted by LD50 View Post
You've still got plenty of time to get it corrected. Just make sure your dealer speaks to the regional rep. Mine is scheduled to be built tomorrow and I didn't find out until last Wednesday or Thursday that there was a problem. I just got an updated build sheet from the dealer this morning and the factory accepted the change.
Thanks LD50 but if I understand it right, I need the luxury package and the Sony nav to get the front camera. I'd have to add about $6k for that. Too pricey for me.
Binks is offline   Reply With Quote
Old 02-16-2012, 08:54 PM   #52 (permalink)
TheJoker's Avatar
Full Throttle Member
Originally Posted by DubbsFaris View Post
Lockpick does NOT allow you to view the FACTORY rear camera unless it is in reverse. In fact, I have an aftermarket rearview camera I had mounted in the same place as the factory camera so I could add a front camera, and in that scenario it doesnt work either. Only way you can do a rear camera in motion is to hook up an aftermarket camera to the 2nd camera input, but then you wont have it when you put your truck in reverse, you will have to manually turn it on through the nav control each time.
OK, so if I understand you correctly, LockPic does not allow a 2nd camera if you have the FACTORY rear camera? But, if you have 2 aftermarket cameras, the rear (input 1) will not activate while in motion but the front (input 2) will?
Why so serious?
TheJoker is offline   Reply With Quote
Old 02-17-2012, 12:31 AM   #53 (permalink)
DubbsFaris's Avatar
Shelby Regional Director
Correct, but a rear afermarket does work in reverse, just not forward if you have the 2nd camera attached to the system.
with that clarification, you have it down!
DubbsFaris is offline   Reply With Quote
Old 02-17-2012, 01:20 AM   #54 (permalink)
Wilson's Avatar
Originally Posted by GvegasRaptor View Post
It is suppose to show up in my display under truck settings but it is missing that icon and is suppose to when enabled be able to view in the large display in the dash just like the rear camera as long as you are going less than 5mph.
15 mph
---------- Post added at 09:07 AM ---------- Previous post was at 09:03 AM ----------
Originally Posted by GJMcManus View Post
Attachment 5859
Front camera
Attachment 5860
wiring harness
Attachment 5861
Wiring harness
Attachment 5862
Front cam on
Attachment 5863
2wd, diff locked, offroad mode
-Greg
I just seen this the camera is worthless if you can't clean it unless you want to get out and clean it all the time what is the point of having it in the first place.
---------- Post added at 09:20 AM ---------- Previous post was at 09:07 AM ----------
never mind
my creative writing skills are nonexistent so put the . , and what ever else is needed in it's place
proud to be loud
2011 Can-Am outlander HMF and chip
2012 Ford Raptor Stainless Works Headers Xpipe true duel SW S-type muffler
Wilson is offline   Reply With Quote
Old 02-17-2012, 08:50 PM   #55 (permalink)
GvegasRaptor
Keep us up to date on whether your dealer figures it out. I think my dealer actually called there to see what was going on and found out they were having some technical difficulties. I thought I had mine taken care of. Got an updated order sheet and the plant accepted the changes. Truck came in today minus the camera so I'm in the same boat now and waiting to see if there's an add on fix.
LD50 is offline   Reply With Quote
Old 02-17-2012, 10:42 PM   #56 (permalink)
If you look today at the Raptor build and price site, the front camera is nowhere to be found...
trailboss is offline   Reply With Quote
Old 02-18-2012, 08:09 AM   #57 (permalink)
Junior Member
Okay so I think I found out why some people are not getting the front mount camera...
If you go to the ford website and download the 2012 F150 brochure go to the page where is says
F-150 Specifications | Optional Feature SVT Raptor
if you look this is what it says/reads
"Front view camera (requires Navigation System and RAPTOR
Luxury Package)"
Hope this helps
I don't know if some have the lux package and nav but did not get the camera. So according to their brochure it looks like ford might have to cover the cost to install one.
I only say this cause there is no where to select it in the biuld and price section but if you have the nav and lux pack then maybe it comes with those options when selected???
Here is the link to the brochure PDF
http://assets.forddirect.fordvehicle...39A23AD739.pdf
scroll down 12 pages.
Currently own a 2002 F150 FX4 Screw...in the process of a L swap supercharger. Flex-a-lite E-fan kit installed.
Someday a future owner of a Blue flame Screw Raptor with all the options and it will be Whipple charged!!!
formuladriver01 is offline   Reply With Quote
Old 02-19-2012, 09:36 AM   #58 (permalink)
Reptar's Avatar
it was never updated to list it. heck the seats are probably still the wrong pattern for blue accent too. They just changed the orange to blue in the photoshop from 2011 to update it for 2012.
Luxury Package)"
Hope this helps
I don't think it'll be on Ford, maybe your salesman and that dealership, but there are a lot of us on here with Front cameras, and our dealers never had any problem reading the build sheet correctly to make sure it was an option selected. Heck it adds something like $595 to the cost of the truck, it's an independent option, not rolled up into another package. It's just linked to other packages requiring you to have nav & lux, but it's still a separate thing to select which adds $595 to the cost to add fr/rr cameras.
REPTAR - 2012 SVT Raptor Supercrew, Ordered 08/26, VIN'd 12/15, Sch'd DAY of 1/19
M.HYDE - 2000 HD F-150 #0356 of 8197, 700/784, 10.32 @ 131.45
D.JEKL - 2000 HD F-150 #1552 of 8197, 372/450, 13.59 @ 100.95 - SOLD
GEN.0L - 1985 XL F-150, 1994 Lightning 5.8L Donor Engine Swap
Reptar is offline   Reply With Quote
Old 02-23-2012, 01:57 PM   #59 (permalink)
GvegasRaptor's Avatar
Okay my Raptor is back at the dealer to hopefully figure out the programming issue with the front camera. The sad thing is that Ford will not help the dealer figure out the problem because it did not come from the factory with the camera. To me that is complete BULL SHIT. I ordered the parts from my dealer (all Ford parts) and I am having a certified Ford tech put it in but they wont help the dealer because it was not built from the factory with the camera. Again I think that is total bull shit!!!
GvegasRaptor
2012 Screw
Greenville NC
GvegasRaptor is offline   Reply With Quote
Old 02-23-2012, 08:25 PM   #60 (permalink)
Maybe I'll have to press them about the issue. After all, I've a build sheet that says I should have gotten a truck with a camera, but no camera on the truck.
Adding front camera, forcing rear camera display: any way to pull this off? Droid Ford Raptor Audio/Video/Electronics Forum 12 04-18-2012 08:05 AM
front camera on 2012 raptor2012 Ford Raptor Forum General Discussions 37 02-12-2012 02:09 AM
Front Camera Findings Humvee21 2012 Ford SVT Raptor Forum 39 02-02-2012 12:55 AM
2012 Front camera in action K9RESQ 2012 Ford SVT Raptor Forum 79 12-28-2011 01:21 AM
Front camera Ryguy84 Ford Raptor Audio/Video/Electronics Forum 2 10-21-2011 10:52 PM
Fully Driven Auto Network
