Originally Posted by Wilson
I looked and can't find it on the forum. and don't have a owners manual yet can I run e-30 in my 2012 6.2 I looked on the net also and thought I found that the 6.2 is flex but don't want to void warranty. I don't want to know how many people hat ethanol I want to know if I can run it if I want to. Thanks'
6.2 a flex.. Thats new to me... Where did you read that??? As far as I know you shouldnt run anything more that the e10 at the pump now...
Well, reading the edmunds its showing that the F250 is FF... and not finding that the F150 is FF
Here is the 2012 Raptor spec.Mechanical
Engine & Performance
Base engine size: 6.2 L
Cam type: Single overhead cam (SOHC)
Cylinders: V8
Valves: 16
Valve timing: Variable
Torque: 434 ft-lbs. @ 4500 rpm
Horsepower: 411 hp @ 5500 rpm
Turning circle: 44.6 ft.
Base engine type: gas
And here is teh F250 Spec
Mechanical
Cylinders: V8
Valves: 16
Torque: 405 ft-lbs. @ 4500 rpm
Horsepower: 385 hp @ 5500 rpm
Base engine type: flex-fuel (FFV)
