Icecobra
Gilroy Garlic capital of the world
Finally installed headrests thanks Raptor Embroidery Raptor Embroidery
Spent a little time today to get my headrests back in thanks to Raptor embroidery a phenomenal job.. oh and installed flashlight mount..
WyoStorm
Wyoming
Installed the JLT oil separator today. piece of cake. however the bottom rubber cover to protect the engine on rubbing fell off in my hand, not sure what they're using to bond it, but they need to change, the rubber around the adhesive just flaked off. I used hot glue, seems to work just fine.
Isn't that true! Mine fell off putting it on the first day too. Definitely not the best part of the design!
TheWolf
Spokane, Washington
EZ Down
Installed the EZ Down using the method in this thread.
Used a 10mm x 5/16 thread ball mount and lock nut instead of the nutsert that it comes with. Added a nylon spacer since the tailgate hole is oblong.
TheWolf
Spokane, Washington
Door Sill Protectors
Found these door sill protectors. They match the existing ones well. As one of the Amazon reviewers noted, I also used a heat gun on the back to get them to form well to the jamb. I also added another strip of double-face tape since the tape that came on them seemed a little thin and may not keep them on.
The front ones are a little shorter than the existing-
And the rear ones are a little longer than the existing-
I could not find these on the manufacturer's website to verify they are for the 2009-2014 Supercrews but a few of the reviewers noted that they used them.
