Punkur67
I rebuilt my front shocks and installed Geiser Bros springs. Gave me 2" of lift.
Wolfpack14
1c3e8d1810fc40fe93791c63fd82897b.jpgd57e0f362283dff9b9045f5b6afc4dbf.jpg Used Griots Iron Fallout Remover for the little rust spots on the truck doors. Took off about 90% of them with just 1 application. Turns purple and runs right off.
Sozzy12
South Idaho
Actually Friday, but I've been out of cell service all weekend... Had the dealer do a Terra kit on the injectors, induction,etc. Supposed to be better than the E-kit. Pretty pleased with the results... Snappier throttle response, and sounds better on startup.
Spent the weekend in the Sawtooth mountains...
J DAMAGE
NJ
What would you use?
I would get a piece of shrink tubing, and unscrew the braided line from the bracket and install it on the braided line, because the dipstick tube is mounted ridged, and the motor is rubber mounted, so you will get movement there. Or put a zip tie around the 2 hoses pulling under the other.
