Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
This is a discussion on What did u do to your raptor today? within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Ok, I did this Saturday, but I'm only getting around to posting now... Installed new ceramic brake pads front and ...
Antlers, upscrazy8
Like Tree29848Likes
Old 11-14-2017, 07:43 PM   #17481 (permalink)
Sozzy12's Avatar
Junior Member
Installed new ceramic brake pads front and rear. The old ones were really thin up front and had some cracks. The rear had more friction material but the shim on each outside pad was loose. Amazing I didn't have any noise.
While the tires were off I put some rust converter on all rusty areas like the caliper and spindle. After it dried, I sprayed it with some black paint. I'll get around to undercoat everything later.
SZDZMTR likes this.
Sozzy12 is offline   Reply With Quote
Old 11-15-2017, 09:33 PM   #17482 (permalink)
Fyrman702's Avatar
Junior Member
Default What did you do to your raptor today?
Over the last week I have gone to mid perch which went pretty smooth in the driveway with hand tools. Used the RPG method from the video. One set screw needed to be drilled out, a little scary drilling into the side of the shock. I just went slow and tapped on the perch until it moved, not too big of a deal.
Purchased Deaver +3's for an awesome price off Craigslist. Also bought RPG bump stop striker plates to install with the springs from Walter @aftermarketheadquarters. Picked up the front spring to frame bolt from Ford so I could cut the bolt next to the fuel tank. Passenger could be cut also but, dropping the exhaust on the passenger side works.
Today I installed the springs with the help of my son, a friend and the lift at my friends shop. Made it easy and only took a little over 2 hours. Also installed RPG bump stop striker plates with the springs for that future upgrade.
I've only driven about 15 miles. Everything feels great. No vibrations. Will check torque after a few hundred miles. Also need to have alignment cams installed and alignment checked soon.
Fyrman702 is offline   Reply With Quote
Old 11-16-2017, 12:55 AM   #17483 (permalink)
+3 side pic of truck?
Heeblet is offline   Reply With Quote
Old 11-16-2017, 12:52 PM   #17484 (permalink)
Fyrman702's Avatar
Junior Member
Here you go. Just after installation, rear measures slightly under 2" of lift.
drj.raptor and Heeblet like this.
Old 11-16-2017, 06:20 PM   #17485 (permalink)
Sozzy12's Avatar
Junior Member
Installed a new tailgate emblem... The dealer had a foil backed sticker on the tailgate that was a PITA to remove... The clear looked a little cloudy so I decided to simply cover it.
FarFromStock likes this.
2012 Raptor SCREW, tuxedo Black
2013 F-250 SCREW, 6.7 PSD
1966 Mustang GT w/ 306, T-5
1977 International Scout Traveler
Old 11-16-2017, 09:30 PM   #17486 (permalink)
dixonk's Avatar
Installed a 20 Baja Designs ONX6 Hi Power. Literally turns night into day. I am in awe at how much light it puts out. Now off to bandage up my cuts and ice my bruises because that thing was a bitch putting in lol.
SZDZMTR and rkneeshaw like this.
dixonk is offline   Reply With Quote
Old 11-17-2017, 01:29 PM   #17487 (permalink)
Wilson's Avatar
put the charger on the battery it was so dead couldn't even get the door to unlock without the key
J. Wolfe likes this.
2018 calendar link >http://www.fordraptorforum.com/f16/2...ictures-54101/
Jeff Ethanol I use it
2012 #3105 Diablosport tune aFe stage 2 SW Headers Xpipe true duel S-type muffler 361rwhp
Wilson is offline   Reply With Quote
Old 11-17-2017, 03:13 PM   #17488 (permalink)
RDFTS's Avatar
aka Rick
These came in today. Going to change the front up a tad. Leaving the rear alone.
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15' | AR Run 15' | TRR Baja 16' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 11-17-2017, 03:15 PM   #17489 (permalink)
SZDZMTR's Avatar
Drive it once in a while. lol
FarFromStock and Wilson like this.
2013 SCREW TUX BLACK LOADED (MONEY PIT)
2011 SCAB MOLTEN ORANGE (SOLD)
SZDZMTR is online now   Reply With Quote
Old 11-18-2017, 12:14 AM   #17490 (permalink)
Tune, cai, larger IC, turbo adapters, down pipes, exhaust, catch can and ran the shit out of it
mmaterni, SZDZMTR and nodirt like this.
Edit Signature Here
Msb.19d is offline   Reply With Quote
Got my Raptor today. AURAPTOR 2013 Ford SVT Raptor Forum (Reply Only) 21 10-28-2012 12:34 PM
Just got my raptor today!!! BENO New Member Check-In 12 12-24-2011 08:47 AM
Raptor Born Today! BWMEEKS Prospective Raptor Owners 11 04-18-2011 11:34 PM
Got My Raptor today! raptorort Ford SVT Raptor General Discussions [GEN 1] 7 04-18-2011 03:25 AM
